Page 1 of 8 123 ... LastLast
Results 1 to 10 of 80
Thread: GFI Requirement?
  1. #1
    Join Date
    Aug 2017
    Los Angeles CA
    Posts
    205
    GFI Requirement?
    10x13sqft residential addition used for show dog grooming (not a business). Los Angeles County. Drywalled including ceiling. Bare concrete floor but sealed. Are GFI outlets required?
  2. #2
    Join Date
    Jun 2014
    Madison, WI, USA
    Posts
    346
    Quote Originally Posted by Andy Delle View Post
    You should just because of the concrete floor. Is it required by code? Probably
    Sent from my A574BL using Tapatalk
    Tell me and I forget. Teach me and I remember. Involve me and I learn.
  3. #3
    Join Date
    Jun 2015
    texas
    Posts
    1,698
    Look at 210.8(A) and see if anything there is applicable- your description is a little too vague to be conclusive if GFCI would be req by the NEC.
  4. #4
    Join Date
    Aug 2017
    Los Angeles CA
    Posts
    205
    In looking again at the plan, I can run all the outlets in a loop. Then I just need a GFI outlet at the first box. Cheap solution!
  5. #5
    Join Date
    Jun 2015
    texas
    Posts
    1,698
    But GFCI may not be required, which is what you asked us in the op.
    Did you find anything that warrants GFCI per the NEC?
    And if you didn't and were going to do it anyway, why ask?
  6. #6
    Join Date
    Jul 2003
    New Jersey
    Posts
    25,837
    Is it in an unfinished basement or other room covered under 210.8? Just because there is a concrete floor doesn't mean that GFCI protection is required. A concrete floor in a finished basement would not require GFCI protection.
    Rob
  7. #7
    Join Date
    Jan 2007
    Posts
    3,660
    Since this is a 10x13 addition, I doubt they are going to dig a hole under the existing house to put the addition in, making me doubt it will actually be considered a basement, which would make me doubt it would need GFI protection on the receptacle outlets.
    JAP>
  8. #8
    Join Date
    Aug 2017
    Los Angeles CA
    Posts
    205
    Quote Originally Posted by user 100 View Post
    I asked to see if it was a NEC requirement. Seems there are still questions so why not just install one at the loop start and be done with it. For $10 why argue?
  9. #9
    Join Date
    Jun 2015
    texas
    Posts
    1,698
    And you did not provide additional info, so we cannot answer anything---is it below ground/are there sink(s) etc.... just thinking something is a good idea is worlds apart from actually being required.
    And you did get a code reference telling you exactly where to look in the NEC.... so what did you find? IOWs, did you conclude GFCI protection is required per the NEC?
  10. #10
    Join Date
    Jul 2003
    New Jersey
    Posts
    25,837
    Wait, didn't you start this thread and ask the question?
    Rob
Posting Permissions
  • You may not post replies
  • You may not edit your posts
