Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 36
Thread: What are the most common mistakes?
  1. #11
    Join Date
    Apr 2007
    Huntington Beach, CA (19 Hrs. 22 Min. from Winged Horses)
    Posts
    6,539
    Quote Originally Posted by marmathsen View Post
    the single most profit sucking mistake on a job?
    blowing the underground. missed walls, missed conduits,
    conduits unfishable. poorly glued pvc that separates.
    ~New signature under construction.~
    ~~~~Please excuse the mess.~~~~
  2. #12
    Join Date
    Feb 2003
    Bremerton, Washington
    Posts
    7,837
    Not using the Mike Holt Code Forum
    Our AHJs put 110.3B at the top of the list and missing KO seals
    Moderator-Washington State
    Ancora Imparo
  3. #13
    Join Date
    Apr 2006
    Simi Valley, CA
    Posts
    8,333
    Quote Originally Posted by nickelec View Post
    Or the most common thing inspectors are wrong about
    Sent from my SM-G950U using Tapatalk
    That contractors know what they're doing.
    I can build anything you want if you draw a picture of it on the back of a big enough check.
    There's no substitute for hard work....but that doesn't mean I'm going to give up trying to find one.
    John Childress
    Electrical Inspector
    IAEI / CEI / C10
    Certified Electrical Inspector
  4. #14
    Join Date
    Jul 2006
    Posts
    7,739
    As a more generalized issue, I'd say it's a tie between NOT READING the code and ASSuming they know what it says / means (see "Charlie's Rule" thread in Campfire chat), or people reading it and not understanding the difference between "minimum" and "maximum" or ASSuming either one is "must be".
    __________________________________________________ ____________________________
    Many people are shocked when they discover I am not a good electrician...
  5. #15
    Join Date
    Oct 2009
    Austin, TX, USA
    Posts
    9,432
    Quote Originally Posted by cowboyjwc View Post
    Actually I've heard that inspectors are requiring it to be wired the other way.
    What? I'd ask the inspector if he'd want to be the one to change out the fuses on a line side interconnected system. I'll stand far away and call 911.
  6. #16
    Join Date
    Jun 2016
    Tampa, FL, USA
    Posts
    1,486
    What are the most common mistakes ... in our industry?
    Not charging enough for your services.
  7. #17
    Join Date
    Apr 2006
    Simi Valley, CA
    Posts
    8,333
    Quote Originally Posted by ggunn View Post
    Because they are looking at it like the PV system is feeding to the panel (like it's usually drawn). Being an electrician I always plan check it backwards from the service to the panels. I just heard someone say that an inspector made him change it the other day, in another jurisdiction of course.
    John Childress
    IAEI / CEI / C10
  8. #18
    Join Date
    Feb 2004
    Posts
    643
    mistake
    Not making sure your brain is engaged before putting mouth in gear.
  9. #19
    Join Date
    Nov 2003
    Roanoke, VA.
    Posts
    4,458
    Stupid S@#$ and lack of paying attention to what you're doing....
    Sometimes I don't know whether I'm the boxer or the bag.
  10. #20
    Join Date
    Dec 2010
    Tennessee NEC:2008
    Posts
    4,607
    Neutrals & grounds not separated in subpanels
    #14 wire on switch legs on a 20A circuit
    If you aim at nothing, you will hit it every time!
Posting Permissions
  • You may not post replies
  • You may not edit your posts
