I have tried demonstrations for a class on the use of Note 3 using equipment in both Col A & Col B.
For example>: (8) 2.5kw units plus (9) 8.5 kw units (unless I made a mistake the result would be 34 kw). If I had the same number of units (17) at 12 kw the Col C result would be 32 kw/
Makes no sense.. 17 ranges all less than 12kw give you a higher number than 17 units at 12 kw.
Am I looking at this wrong ?
