Page 1 of 4 123 ... LastLast
Results 1 to 10 of 36
Thread: Mislabeled submersible pump?
  1. #1
    Join Date
    Mar 2007
    Valdosta, GA
    Posts
    4,000
    I recently installed a VFD for a 20HP submersible pump used for irrigation.
    The customer added a backup 20HP pump last week, so we installed a double-throw switch ahead of the VFD to connect both.
    The new pump is causing an overload shutdown on the drive.
    Existing 20HP pump pulls 55A. The new pump pulls 66A. The box clearly says it’s a 20HP pump, and per the manufacture chart should pull 54.3A.
    Could the FLA vary that much, or is it likely mislabeled?
    Per the same chart the 25HP has an FLA of 65A. Just by the numbers I think they installed a 25HP.
    Brought to you by Carl's Jr.
  2. #2
    Join Date
    Sep 2008
    UK
    Posts
    11,344
    Quote Originally Posted by brantmacga View Post
    Just a thought are the motors physically the same size?
  3. #3
    Join Date
    Jun 2003
    NE (9.1 miles @5.07 Degrees from Winged Horses)
    Posts
    9,599
    A double throw switch ahead of the VFD to connect both?
    Tom
    TBLO
  4. #4
    Join Date
    Sep 2008
    UK
    Posts
    11,344
    Quote Originally Posted by ptonsparky View Post
    I assumed either rather than both.
  5. #5
    Join Date
    Dec 2007
    NE Nebraska
    Posts
    36,695
    Do you have same flow rate, pressure and amount of lift for both pumps? Vary any of those and the motor shaft sees a different load. Difference in pump speed or impeller design can change flow or pressure when everything else is the same.
    ADD:
    In fact a restriction in one output line that goes unnoticed will lessen flow and will have lesser load on that pump with everything else being the same.
    I live for today, I'm just a day behind.
  6. #6
    Join Date
    Jun 2003
    Posts
    9,599
    Submersibles often run into SFA. Is the pump running open discharge? Worst case scenario esp if it happens be a bit further down the hole.
    Tom
    TBLO
  7. #7
    Join Date
    Mar 2007
    Valdosta, GA
    Posts
    4,000
    It is ... they haven’t plumbed it into existing system yet. But so was the existing motor when I installed the Vfd.
  8. #8
    Join Date
    Jun 2016
    Tampa, FL, USA
    Posts
    1,466
    If the pump has a bad bearing or anything else that slows it down, the amp draw will rise.
  9. #9
    Join Date
    Mar 2016
    The Motor City, Michigan USA
    Posts
    707
    ... if it happens be a bit further down the hole.
    The depth of the water, not the depth of the pump, determines the pressure difference across the pump.
    (along with other factors that are presumably constant)
  10. #10
    Join Date
    Jun 2003
    Posts
    9,599
    Quote Originally Posted by drcampbell View Post
    yes, I misspoke.
    Tom
    TBLO
Posting Permissions
  • You may not post replies
  • You may not edit your posts
