User Tag List
Page 1 of 2 12 LastLast
Results 1 to 10 of 15
Thread: CLAMP BACK/BACKSTRAP
  1. #1
    Join Date
    Sep 2012
    NJ
    Posts
    2,288
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    If running 3/4" or 1"EMT exposed on concrete wall so you usually use these or just with RGS? Thanks.
  2. #2
    Join Date
    May 2005
    Richmond, Virginia
    Posts
    23,947
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I use typical 1-hole straps, unless the quantity calls for strut and strut-straps. What are you referring to?
    Code references based on 2005 NEC
    Larry B. Fine
    Master Electrician
    Electrical Contractor
    Richmond, VA
  3. #3
    Join Date
    Jul 2005
    Tennessee
    Posts
    16,012
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    wet location ??
    At my age, I'm accustomed to restaurants asking me to pay in advance, but now my bank has started sending me their calendar one month at a time.
  4. #4
    Join Date
    Jul 2015
    Soldotna, AK, USA
    Posts
    133
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by mstrlucky74 View Post
    Whats RGS?
  5. #5
    Join Date
    Jul 2003
    New Jersey
    Posts
    26,359
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Rigid Galvanized Steel which is a type of RMC.
    Rob
  6. #6
    Join Date
    Sep 2011
    woodbridge, ct. USA
    Posts
    1,133
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    They make one hole straps for rigid also. I had some one tell me once if you ran the pipe horizontal you had to put the strap below the pipe. (so the pipe doesn't jump out of the strap)
  7. #7
    Join Date
    May 2005
    Richmond, Virginia
    Posts
    23,947
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Despite having heard that, I always put 1-holes on with the strap above the conduit, because that way the conduit hangs straight down from the screw. With the strap below the conduit, the pull is away from the wall, possibly pulling anchors out of the holes.
    Larry B. Fine
    Master Electrician
    Richmond, VA
  8. #8
    Join Date
    Feb 2009
    Durango, CO, 10 h 20 min without traffic from winged horses.
    Posts
    9,855
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by LarryFine View Post
    You and me against the world, baby.
    If you don't think too good, don't think too much.
  9. #9
    Join Date
    Sep 2012
    NJ
    Posts
    2,288
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by AKElectrician View Post
    Whats RGS?
    rigid galvanized steel conduit
  10. #10
    Join Date
    Dec 2007
    NE Nebraska
    Posts
    38,818
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by GerryB View Post
    Use the heavier walled straps and it don't really matter too much.
    I live for today, I'm just a day behind.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
