User Tag List
Page 3 of 3 FirstFirst 123
Results 21 to 22 of 22
Thread: indoor unit disconnect
  1. #21
    Join Date
    Feb 2003
    Somewhere over the rainbow
    Posts
    3,295
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by kwired View Post
    You said "The indoor unit of a heat pump will turn off when the outdoor unit's disconnect is turned off." Not true for the majority of the units. You will still have indoor unit running and will still have 24 volts to the contactor coil of the outdoor unit because the control power comes from the indoor unit. The compressor will stop and you won't get any heat/cooling from the refrigerant but the indoor blower and any back up heat still function.
    I will agree with you if the indoor unit has different circuit than the outdoor unit. Most of the heat pumps that I have wired have one circuits to the outdoor then wires into the indoor unit.
    Edward
    The only thing I know, is the progressive discovery of my ignorance
  2. #22
    Join Date
    Dec 2007
    NE Nebraska
    Posts
    38,818
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by edward View Post
    About the only ones I have seen this way are the "mini-split" type units. The conventional split unit type system has power supply to both units and control power comes from the indoor unit. Indoor unit can be just an air handler, air handler with electric heat, or a gas furnace and still use same outdoor unit.
    Mini-splits and other similar designed units are more designed to use with more specific indoor units, conventional North American design systems are a little more generic and can be used with many indoor units.
    I live for today, I'm just a day behind.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
