User Tag List
Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: in line fuse holder
  1. #11
    Join Date
    Jun 2003
    NE (9.1 miles @5.07 Degrees from Winged Horses)
    Posts
    10,301
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks for the definition. Makes sense.
    Tom
    TBLO
  2. #12
    Join Date
    Jan 2018
    SE Michigan
    Posts
    120
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by ptonsparky View Post
    Not in the fixture. More likely in the jbox directly above it. Not sure if that is even legal. in the thinking stage yet.
    These could be mounted in a 1/2" KO when inserted from the outside the box and two holes drilled/ tapped and be used with spade terminals up to 20A. Rated to 600V
    I have ordered fixtures in the past with these type units factory installed.
    http://www.cooperindustries.com/cont...rs_(amps).html
    MTW
  3. #13
    Join Date
    Dec 2006
    Eastern Oregon
    Posts
    3,655
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I had some issues with some 400w MH low bays in a dairy once. I was able to find some inline fuseholders similar to what MTW posted in either a Littelfuse or Bussman catalog.
    I put them right in the wiring j-box at the top of the fixture, that was 2-3 years ago and I haven't had a call for them since.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
