Results 1 to 4 of 4
Thread: 4/0 cable from meter into 2x4 wall?
  1. #1
    Join Date
    Oct 2014
    United States, Indiana
    Posts
    350
    Is it ok to install 4/0 3 wire AL SER cable from back of a meter then vertically into a 2x4 wall?
    is that too sharp of a bend, radius wise? I can physically do it but is that too tight of a bend ? Thank you, just checking if you normally do that? Thank you.
  2. #2
    Join Date
    Nov 2010
    Fort Collins, Colorado
    Posts
    2,692
    Quote Originally Posted by Stevenfyeager View Post
    338.24. Widely violated due to these conditions.
  3. #3
    Join Date
    Jun 2003
    Hawthorne, New York NEC: 2014
    Posts
    3,828
    I would also think about running the service entrance within a wall.
    -Hal
  4. #4
    Join Date
    Jun 2004
    Cherry Valley NY, Seattle, WA
    Posts
    4,629
    I dont think its a problem. Done all the time around here. 4 out of 5 houses around here have SEU going down the wall, then bends 90 degree to go in. Often a sill plate is used over the transition.
    Ethan Brush - East West Electric. NY, WA. MA
    "You can't generalize"
Posting Permissions
  • You may not post replies
  • You may not edit your posts
