User Tag List
Results 1 to 7 of 7
Thread: Ballast Quality . ( Which Manufactures are the best ? )
  1. #1
    Join Date
    Jul 2008
    North Of Tampa Fl
    Posts
    466
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Have quite a few 150 watt metal halide fixtures that the ballast's are bad . The one's that in in them now are ( Sola E-MZAOOW150 ) . How do you determine what manufacture type you would use to get the longest life out of them ???
  2. #2
    Join Date
    Apr 2009
    Williamsburg, VA
    Posts
    6,042
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I've had good luck with Advance products. If the lifespan of the metal halide ballast you have in there now has been low, I would definitely not replace them with an oem ballast. I dont have too much experience with metal halide though. I have seen far far more fluorescent fixtures with poor ballast life, often shorter then the time it takes for the bulbs to be halfway worn out. I almost never put OEM ballasts back in any of those fixtures.
    Eta: many times, by the time ballast needs to be replaced, the fixtures themselves really aren't too far behind... May want to do a cost-benefit of replacing the entire thing
  3. #3
    Join Date
    Jan 2011
    United States
    Posts
    9,126
    Mentioned
    1 Post(s)
    Tagged
    1 Thread(s)
    Advance by far.
  4. #4
    Join Date
    Nov 2014
    Miami, Florida, USA
    Posts
    211
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    I use Advance most often as well.
    You could consider going with an electronic ballast. Lamps should last longer and they are more energy efficient. I have no experience with them however and we recently went the LED path.
  5. #5
    Join Date
    Jun 2003
    Posts
    7,055
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    If you don't mind having a mix of fixtures in the space (assuming its a warehouse, or factory or something similar), I would definitely look at replacing the entire fixture with LED before replacing a ballast.
    The energy savings will quickly pay for the difference in cost.
  6. #6
    Join Date
    Apr 2018
    Minneapolis´╝îMinnesota´╝îU.S.
    Posts
    5
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Agree, LED is more energy saving and environmentally friendly, reducing your electricity bills. Or you can choose bypass ballast LED light, saving the money for ballast.
  7. #7
    Join Date
    Mar 2003
    New England
    Posts
    13,932
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    An HID ballast should be destined for the scrap yard, not replacement.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
