Results 1 to 2 of 2
Thread: Unsupported Long Vertical Runs of Electrical Cords & Welding Cables
  1. #1
    In construction, it is common to see long vertical runs of electrical cords and welding cables extending from the ground to high work elevations. In most cases, such runs are not supported which, I believe, can cause elongation of conductors and strech insulation. Such conditions can create hazards to personnel if damages go unnoticed.
    Does the NEC/UL/NEMA address this subject and if so what specific section(s)?
    Need to know the method/type of support(s), support spacing, when needed, etc. Such info is good ammunition for the enforcement of precautions on construction sites.
    Assistance and cooperation appreciated.
  2. #2
    Join Date
    Apr 2009
    Williamsburg, VA
    Posts
    5,030
    I would look under OSHA rules. I'm pretty sure they're supposed to be tied off every x amount of feet... Even the end of a lightweight 12 gauge extension cord falling and whippin 40 ft can cause serious damage.
    Eta: article 400 of the NEC addresses flexible cords, and 590 addresses temporary installations, and article 640? Welders, tho I do not believe you will find any information in the NEC regarding your concerns.
    cable stretch and damage under its own weight is a concern, Though falling cables and trip hazards are probably much more an issue.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
