User Tag List
Page 2 of 13 FirstFirst 1 2 3 4 12 ... LastLast
Results 11 to 20 of 123
Thread: How does the neutral wire prevent MWBCs from operating at 240v?
  1. #11
    Join Date
    Sep 2008
    UK
    Posts
    12,703
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by ActionDave View Post
    Roger's diagrams, Larry's written explanation, and the video Jamesco posted all do a good job of telling us what the neutral does but none explain why. How do the electrons on an unbalanced MWBC coming from phase A know they are supposed to turn right and head down the neutral path, and the electrons from phase B know they are supposed to turn left and head down the same neutral? Why don't they go wherever they want on whatever copper wire they like the best?
    Common misconception about electrons and ac.
  2. #12
    Join Date
    Feb 2009
    Durango, CO, 10 h 20 min without traffic from winged horses.
    Posts
    9,944
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Besoeker View Post
    I'm a commoner.
    If you don't think too good, don't think too much.
  3. #13
    Join Date
    May 2005
    Richmond, Virginia
    Posts
    24,691
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    It's all because of voltage applied and resultant current. The neutral carries whatever current it must to keep the load end neutral point at the same relative voltage as the supply end of it, the same way the line conductors do the same thing: keep the load end at the same potential as the supply end.
    Current through the resistance of the wire causes that effort to slightly fail, and we call the result voltage drop. It happens on the neutral as well, but only to the extent of that caused by the difference between the loads on each line. So, the direct answer to your question is "the relative impedances".
    Code references based on 2005 NEC
    Larry B. Fine
    Master Electrician
    Electrical Contractor
    Richmond, VA
  4. #14
    Join Date
    Jan 2011
    United States
    Posts
    8,803
    Mentioned
    1 Post(s)
    Tagged
    1 Thread(s)
    Phase angle. The electrons go where ever forces (magnitude and angle) push them.
    I'm in over my head...
  5. #15
    Join Date
    Apr 2009
    Williamsburg, VA
    Posts
    6,042
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    If you think of electricity as a living thing, it is lazy and resourceful. The neutral is the path of the least resistance back to the source so it will take that path versus going through another piece of equipment with high resistance.
    If you remove the neutral on a multiwire branch circuit or a service, electricity is still going to find a way back to the source it will just have to go through the other phase and the equipment attached to it. Unless both pieces of equipment have almost the same resistance, one will see a higher voltage than the other, and if it's bad enough, that piece of equipment will let out the Magic Smoke.
    In Lay terms that's about the best way I can explain why the neutral works.
    ( and yes, I'm aware that electricity takes all paths back to the source)
  6. #16
    Join Date
    Sep 2008
    UK
    Posts
    12,703
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I'm a commoner.
    And I'm sure you have abundant capacity to learn...............
  7. #17
    Join Date
    Dec 2007
    NE Nebraska
    Posts
    40,124
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by JFletcher View Post
    But only the unbalanced current is what returns on the neutral.
    Now complicate it with the 120 degree phase angle of a three phase wye system. Still similar concepts but it doesn't balance out the same way, especially when only two lines and the neutral are what is involved.
    I live for today, I'm just a day behind.
  8. #18
    Join Date
    Apr 2007
    Berkeley, CA
    Posts
    1,802
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    The electrons do go wherever they want--it's a question of determining the rules that express what they want. What electrons want is to reduce their energy, and voltage is a measure of the energy per electron. So electrons want to move from higher voltage to lower voltage. [The analogous way of looking at gravity is to say that objects want to reduce their potential energy, that is why they move from a higher altitude to a lower altitude, i.e. fall.]
    When we wire up the MWBC, we want the electrons to give up the same energy (per electron) in each of the two loads. The neutral connection, as a source or sink of electrons at the midpoint energy, ensures they do this. If the electrons started to give up more or less energy (per electron) in one load, the energy imbalance would cause more electrons to flow through the neutral connection one way or the other to counteract that imbalance.
    Cheers, Wayne
  9. #19
    Join Date
    Aug 2017
    Los Angeles CA
    Posts
    215
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by romex jockey View Post
    If i'm reading you right it's because a 120V load uses one side of the cycle , not both
    ~RJ~
    No, both the side of the sinewave are used. It's just that they are 180 degrees out of phase. So at any given instant the neutral only sees the current on either the positive or negative sinewave, not both.
  10. #20
    Join Date
    Dec 2012
    Placerville, CA, USA
    Posts
    20,129
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Andy Delle View Post
    No, both the sin and cosine are used. It's just that they are 180 degrees out of phase. So at any given instant the neutral only sees the current on either the sine or cosine load, not both.
    The sine and cosine functions are 90 degrees out of phase, not 180.
    The two lines in 120/240 3-wire single phase are +sin(omega*t) and -sin(omega*t) respectively.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
