User Tag List
Results 1 to 2 of 2
Thread: Eiko t8 led lamps type b
  1. #1
    Join Date
    Apr 2018
    Missouri
    Posts
    27
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    We are in the process of replacing approximately 7000 T8 and T12 lamps throughout our school district. I am looking at an Eiko,T8, ballast bypass,direct wire, dual ended lamp, 17 Watt. Most of our lighting is 277 volts, most fixtures have a reading of 280 - 285 bolts at the fixture. A lot of the rooms run off of two switches with a shared neutral. I'm not sure if we have a lot of voltage spikes or not but I can't say during a lightning storm our power will dim out briefly, without going out completely. Is there anything I need to be aware of or look for before starting this project? Is eiko a good brand, is type B the way to go, should I consider surge protectors at our panel
  2. #2
    Join Date
    Feb 2003
    Fl
    Posts
    17,560
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Duplicate
    Roger
Posting Permissions
  • You may not post replies
  • You may not edit your posts
