User Tag List
Page 2 of 2 FirstFirst 1 2
Results 11 to 14 of 14
Thread: Service conductor length before needing a disconnect.
  1. #11
    Join Date
    Dec 2011
    Wisconsin
    Posts
    606
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by charlie b View Post
    Washington state code explicitly states that the limit here is 15 feet. I don't know if MN has a similar code. Have you looked for applicable state codes?
    I believe that MN adopts the NEC in its entirety without amendments.
  2. #12
    Join Date
    Dec 2011
    Ocala, Florida, USA
    Posts
    3,038
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by packersparky View Post
    But the point is that the NEC is ambiguous. Florida adopts the NEC and doesn't allow local jurisdictions to pass any rules more or less stringent than the code. The allowance for the code we are discussing changes from one jurisdiction to another because the NEC doesn't give a definitive distance.
    I know what I don't know, and I know where to go to find it!
  3. #13
    Join Date
    Dec 2011
    Wisconsin
    Posts
    606
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Strathead View Post
    I understand that, that is why I responded to Charlie that the OP would not find a definitive answer in any MN code.
  4. #14
    Join Date
    Sep 2011
    woodbridge, ct. USA
    Posts
    1,168
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Around here you can do a panel swap with no permit, unless the HO wants one. The poco will allow you to pull the meter and put it back in. If it is locked they will unlock it for you. You do need to have an E1 (unlimited electrical contractor) liscense.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
