User Tag List
Results 1 to 6 of 6
Thread: Central Station
  1. #1
    Join Date
    Sep 2012
    NJ
    Posts
    2,354
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Central Station
    The DACT is not on the symbol list. I believe it's a dialer. What's the usual wiring scenario to get a connection the central station?
    Attached Images Attached Images
  2. #2
    Join Date
    Aug 2009
    Cypress, CA
    Posts
    56
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Typically a DACT communicates with the FACP via relays, alarm, trouble, & supervisory. Unless the FACP & DACT have a compatible method of communication like an annunciator bus or RS-232.
    This would depend on what model FACP & DACT you have. Most FACP models now have a DACT built-in or one that can be added inside the FACP cabinet.
    In the older days the DACT would communicate to central station via 2 phone lines. Now NFPA 72 requires two separate methods of communication, 1 phone line, 1 IP, cellular, or radio dialer. Otherwise you could use a solepath dialer like the Telluar TG7 cellular dialer.
  3. #3
    Join Date
    Feb 2018
    US
    Posts
    23
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Central Station
    Either 2 phone lines, 1 dedicated and 1 seizure, or a radio dialer. The most common I know of are AES and Telguard.
  4. #4
    Join Date
    Oct 2007
    New Jersey
    Posts
    6,325
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by ryant35 View Post
    In the old days it was still 2 methods and it was two phone lines because POTS lines were considered the gold standard for reliability. Even back to 2002, though, you could use an alternate method for line 2, but line 1 HAD to be a POTS. Now POTS is only allowed, not required, and as the secondary. How times change.
  5. #5
    Join Date
    Oct 2007
    New Jersey
    Posts
    6,325
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Fire Pro View Post
    I have used AES and they are very good. The also come with a dialer so you don't need a separate box for the alternate path.
  6. #6
    Join Date
    Sep 2012
    NJ
    Posts
    2,354
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
