User Tag List
Page 1 of 2 12 LastLast
Results 1 to 10 of 13
Thread: Musings on snow on panels and production estimating
  1. #1
    Join Date
    Jun 2004
    Cherry Valley NY, Seattle, WA
    Posts
    5,036
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Do the values in PV watts take into account snow covering the modules for significant periods during the winter? Anyone heard of an analysis of different panel tilts and its effect on snow shedding?
    Ideal fixed tilt here near Albany NY is 34 degrees. 22 degrees only results in 2% less annual production - in theory. But how much quicker will they shed snow? Dec Jan and Feb together are 17% of annual production. This gets back to the first question, but I assume that assumes no snow cover. WAG, 1/4 of the time covered with snow at 34 degrees, 3/4 of the time at 22 degrees?
    Ethan Brush - East West Electric. NY, WA. MA
    "You can't generalize"
  2. #2
    Join Date
    Jun 2004
    Posts
    5,036
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Very old, but interesting. In particular, see page 11:
    https://www.osti.gov/scitech/servlets/purl/5232456
    A brief primer on a model in SAM:
    https://sam.nrel.gov/sites/default/f...Snow_Model.pdf
  3. #3
    Join Date
    May 2011
    Posts
    4,860
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Keep in mind that snow reflectance from the ground can increase irradiance and thus increase winter output beyond the expected. A higher tilt is better for that, too. I can't point to any kind of robust analysis but my intuition says to go with the higher tilt, all else being equal.
  4. #4
    Join Date
    Oct 2007
    New Jersey
    Posts
    6,325
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by electrofelon View Post
    When you measure tilt that way, are you talking about raising the top from horizontal, or raising the bottom from vertical?
  5. #5
    Join Date
    May 2011
    Posts
    4,860
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    From horizontal.
  6. #6
    Join Date
    Oct 2007
    New Jersey
    Posts
    6,325
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by jaggedben View Post
    From horizontal.
    That didn't seem to make sense, so I went here and confirmed my hunch that it is from vertical, as in pin the top of the panel like it's the rear door of a hatch-back and lift from the bottom. 90 degrees would be parallel to the ground, 0 degrees is perpendicular to the ground. According to the calculator the ideal sun angle for Albany, NY varies from 24 in December to 70 in June.
  7. #7
    Join Date
    Jun 2004
    Posts
    5,036
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Yeah good point.
  8. #8
    Join Date
    Jun 2004
    Posts
    5,036
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by gadfly56 View Post
    This site has the equations:
    http://www.solarpaneltilt.com/
    The common theory of "set them to your latitude" is incorrect.
  9. #9
    Join Date
    Apr 2007
    Berkeley, CA
    Posts
    1,795
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    That didn't seem to make sense, so I went here and confirmed my hunch that it is from vertical.
    You found a site using that convention. This thread has been using the other convention, as does the site that electrofelon mentioned, as does the (non-optimal) rule of thumb "tilt angle = latitude".
    Cheers, Wayne
  10. #10
    Join Date
    May 2011
    Posts
    4,860
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Industry standard, at least in this country, is tilt is from horizontal. In the decade I've been doing this I've never seen or heard anyone measuring from vertical. See Solmetric tools, for example. Or PVwatts. Or CSI.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
