User Tag List
Results 1 to 6 of 6
Thread: Wiring 0-10v
  1. #1
    Join Date
    Sep 2012
    NJ
    Posts
    2,357
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Wiring 0-10v
    Need a little help with wiring here. So the type B&Cfixtures show as 4 wire 0-0v in the schedule. The cuts show input as 120v. Twoquestions:
    1. Don’t think I need to bring 4 wires to the fixture
    2. I don’t think I need 0-10v wiring from switches tofixture.
    3. If I’m correct on #2 were is the 0-10v…within thefixtures? They do have 0-10v drivers.
    Just want to make sure I wasn’t confusing it and it was theother way around and bringing 0-10v to fixture then the driver to light is120v. 99% it’s 120v wire from switch to driver. The 4 wire 0-10v listed in the schedulethrew me off. Thanks.
    This link is for the switch for the type B.
    https://www.lutron.com/TechnicalDocu...ary/369748.pdf
    Attached Thumbnails Attached Thumbnails Click image for larger version.
Name:	Type B part 2 PNG.jpg
ID:	20195   Click image for larger version.
ID:	20196   Click image for larger version.
Name:	Type C part 2.jpg
ID:	20197   Click image for larger version.
ID:	20198   Click image for larger version.
Name:	Type C dimmer.jpg
Name:	FIXTURE SCHEDULE.jpg
  2. #2
    Join Date
    Mar 2018
    Los Angeles, California, USA
    Posts
    6
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    The fixture driver has the 0-10 integrated... The dimmer switch referenced will not work to dim the lights, you need one specifically for 0-10. If there is no controllers involved, ie. Nlight, stopper... Etc then you would need to run the four conductor wire (power and 0-10 control) from switch to lights
    Sent from my SM-N950U1 using Tapatalk
  3. #3
    Join Date
    Sep 2012
    NJ
    Posts
    2,357
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Correction I think this would be the switch for the type C.
    Attached Images Attached Images
  4. #4
    Join Date
    Mar 2018
    Posts
    6
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by mstrlucky74 View Post
    That is the dimmer switch you need to use for 0-10 dimming application
  5. #5
    Join Date
    Jan 2018
    US
    Posts
    2
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Ubiquitous View Post
    If you need to dim the light they sell the mc with the 0-10v volt wire inside or you can use cat5 or cat6 long side the mc
    Sent from my SM-N950U using Tapatalk
  6. #6
    Join Date
    Sep 2012
    NJ
    Posts
    2,357
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by flash101 View Post
    Yes I know, the MC PCS cable, thanks. Wondering if the make hospital grade...have to check.
    Edit..they do.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
