User Tag List
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 13
Thread: 4" Box Gyp Clg.
  1. #1
    Join Date
    Sep 2012
    NJ
    Posts
    2,441
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    4" Box Gyp Clg.
    Have a bunch of fire alarm devices mounted in gyp boardceiling that need 4” box. Usually use a T-Bar hanger when have 2x2 acousticalceilings. What is typically used to support box in gyp board ceiling? Thanks.
  2. #2
    Join Date
    Oct 2015
    US
    Posts
    877
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Is the sheet rock already up ? If not use a bar box
    Sent from my SM-G950U using Tapatalk
  3. #3
    Join Date
    Jul 2003
    New Jersey
    Posts
    27,001
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    If the device fits an octagon box I would do as Nick suggested.
    Rob
  4. #4
    Join Date
    May 2017
    SCV Ca, USA
    Posts
    538
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by infinity View Post
    I think there is a dysfunction going on here.
    O.P says they are 2'x2' accoustic ceiling tiles. Never heard of gypsum sheet rock, t-bar mounted ceiling tiles.
    They are too heavy for T-bar mounting. There are gypsum board accoustic panels but they are for wall mounting and 4' x 4' feet typically--not 2'
    x 2'.
    There are special t-clips for box mounting used in accoustic ceilings. You may need additional wire hangers (sometimes required) for the T-bar if you install a device.
    The ceiling accoustic tiles are lightweight--only a fraction of the weight compared to gypsum sheet rock boards.
    Look in commercial applications for this specific installs.
    Seems like you haven't done commercial before?
  5. #5
    Join Date
    Jul 2003
    New Jersey
    Posts
    27,001
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by myspark View Post
    x 2'.
    You misread the OP. He said that when using 2X2 tiles he uses T-bar hangers. Now he has a Sheetrock ceiling to deal with.
    Rob
  6. #6
    Join Date
    Mar 2007
    Valdosta, GA
    Posts
    4,474
    Mentioned
    1 Post(s)
    Tagged
    1 Thread(s)
    4" Box Gyp Clg.
    ....Never heard of gypsum sheet rock, t-bar mounted ceiling tiles.
    x 2'.
    Every kitchen I’ve worked in has gypsum ceiling tile panels.
    Also in 2hr rated ceilings.
    Brought to you by Carl's Jr.
  7. #7
    Join Date
    May 2005
    Richmond, Virginia
    Posts
    24,775
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by brantmacga View Post
    And for some reason they feel twice as heavy as a piece of drywall the same size.
    Code references based on 2005 NEC
    Larry B. Fine
    Master Electrician
    Electrical Contractor
    Richmond, VA
  8. #8
    Join Date
    May 2017
    SCV Ca, USA
    Posts
    538
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    We are talking about accoustic ceiling. Local department of health does not allow porous surfaces in places where food is prepared.
    A homeowner can have anything she/he wants but that doesn't mean having porous ceiling or walls (in kitchen) is an accepted practice and sanctioned by regulators.
    Surfaces must be impervious.(non-absorbent).
  9. #9
    Join Date
    Jul 2003
    New Jersey
    Posts
    27,001
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    They make gypsum tiles for lay-in style ceilings. From USG:
    features and benefits
    USG Sheetrock® Brand Lay-in Gypsum Ceiling Panels are the ultimate choice for meeting USDA/FSIS requirements. Aside from adhering to government standards, they offer excellent fire protection. USG Clean Room® panels are also available that meet Class 100/ISO Class 5 and 10M-100M clean room standards.
    • USG Clean Room® panels have a vinyl-laminated face with sealed back and edges for use in clean room environments up to Class 100/ISO Class 5
    • Washable and scrubbable finish — impact and scratch resistant
    • USDA Certified Biobased Product
    • Low-emitting product meets CA Specification 01350, California Department of Health Services Standard Practice for the testing of VOC emissions
    • Panels meet USDA/FSIS requirements for food processing areas
    • ClimaPlus™ 30-year lifetime system warranty against visible sag
    https://www.usg.com/content/usgcom/e...ng-panels.html
    Back to the OP this has nothing to do with lay-in ceilings.
    Rob
  10. #10
    Join Date
    Apr 2003
    Planet macmikeman
    Posts
    3,490
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    !/4" threaded rod hangers. 1/4-20 nuts with washer's to hold the box in place. Drop anchor to the concrete (?) ceiling above or else, if wood, then a spearpoint coupling screwed into the wood or beams. Cordless band saw makes or breaks such a job.
    85deg. an Sunny today.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
