User Tag List
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 15
Thread: Running Risers
  1. #1
    Join Date
    Sep 2012
    NJ
    Posts
    2,441
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Running Risers
    If you had s new construction with metal deck and poured slab do you think labor installing riser conduits would be different if you were running through a closet or through shaft/slot? Don't see how it would make a difference.....it would just be an opening in either case.
  2. #2
    Join Date
    Jul 2003
    New Jersey
    Posts
    27,001
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    A hole is a hole, shouldn't matter if you're running the risers after the pour through a slot.
    Rob
  3. #3
    Join Date
    Sep 2012
    NJ
    Posts
    2,441
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by infinity View Post
    Figured that. Any things you've come across running risers that stand out to be aware of?
  4. #4
    Join Date
    Apr 2009
    Williamsburg, VA
    Posts
    6,042
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I am not familiar with the installation you are talking about. Core drilling and where those cords can be drilled if in a tension slab can be a fairly significant cost
  5. #5
    Join Date
    Jul 2003
    New Jersey
    Posts
    27,001
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by mstrlucky74 View Post
    Make sure that the slots in the deck are the right size and line up with each other or you end up with this.
    Click image for larger version.
    Rob
  6. #6
    Join Date
    Jul 2003
    New Jersey
    Posts
    27,001
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Rob
  7. #7
    Join Date
    Sep 2012
    NJ
    Posts
    2,441
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    lol...nice offsets. thx
  8. #8
    Join Date
    Sep 2012
    NJ
    Posts
    2,441
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    BTW is there metal deck within that slab? How was that opening created? Formed out? Thanks
  9. #9
    Join Date
    Jul 2003
    New Jersey
    Posts
    27,001
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    No metal Q-deck just forms, rebar, and concrete. The slots we're boxed out before the deck was poured. We had several locations where they were incorrect and didn't align with the floor above. Estimate called for straight pipe....
    Rob
  10. #10
    Join Date
    Sep 2012
    NJ
    Posts
    2,441
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Shouldn't that be a change order?
Posting Permissions
  • You may not post replies
  • You may not edit your posts
