User Tag List
Page 2 of 9 FirstFirst 1 2 3 4 ... LastLast
Results 11 to 20 of 81
Thread: Voltage Unbalance Reason
  1. #11
    Join Date
    Jan 2016
    Earth
    Posts
    6,049
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by GoldDigger View Post
    See post #6 for how it can be.
    I sketched it out
    l-n 600/0
    the other x/120
    the sum (rather than subtract as if pol was reversed) being 200/30
    can't find an x that works
  2. #12
    Join Date
    Aug 2008
    San Francisco
    Posts
    753
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Gentlemen
    pls re-read post #8 that addresses these issues
    and comment back
    Am I in shape?? I get plenty of exercise pushing my luck!!
  3. #13
    Join Date
    Jan 2016
    Earth
    Posts
    6,049
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    he has the same set up on the other sets
    n is floating, but the others read ok
    has it ever worked correctly?
    is it a new install being commissioned?
    the only way I can see those magnitudes
    l-n ~600
    l-n ~ 150 with a 300
    is the neut having 600/0 +/- 15-20 deg phasing vs +/- 120 deg
    no idea how you would get that
  4. #14
    Join Date
    Feb 2003
    New York, 40.7514,-73.9925
    Posts
    4,641
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by ATSman View Post
    Gentlemen
    and comment back
    Sometimes I wonder if it is worth challenging someone that is so sure of themself. That's why I thought my suggestion was fair earlier too.
    Ron
  5. #15
    Join Date
    Feb 2013
    India
    Posts
    2,555
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by mrmuneeb View Post
    dear All,
    Hi, I am having a problem of unbalanced strange values of system voltages in of our power generation plant,
    the disturbance in voltage is being reflected on Low voltage side only,
    system diagram is attached.
    Attachment 20244
    what the system must show at low voltage side is;
    1. P-P 480V
    2.P-N 277V
    but the current scenario on delta side of transformer is;
    L1-L2= 316 V
    L2-L3= 147 V
    L3-L1= 221 V
    L1-N= 594 V
    L2-N= 599 V
    L3-N= 530 V
    neutral is kept floating on both sides, i.e. both LV & MV neutral is floating.
    is there any fault in on of the system phases?
    The vector sum of line or phase voltages, whether balanced or not, of the generator should equal zero i.e they form a closed triangle. If it is not so with your readings i.e a closed triangle is not possible even approximately, it means the phase angle between phase windings are not correct i e the winding issue.
  6. #16
    Join Date
    Jan 2016
    Earth
    Posts
    6,049
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Gentlemen
    and comment back
    a floating neut will not make v l-n 3 x v l-l
    either he made a posting error and v l-l is 600 and v l-n 150-300 or there are major connection issues
    the ONLY way for this to occur
    v l-n for a, b, c ~ 600/0, +15-20, -15-20 deg
    this will give a l-l using a ph ~ +/- 17 deg
    v a + (- v b) = vab
    va = 600 + 0j
    vb = -(575 + 175j)
    vab = 25 + 175j = 175/82
    similarly vac ~ 175/-82
    vbc
    0 + 350j ~ 350/90
  7. #17
    Join Date
    Jun 2003
    NE (9.1 miles @5.07 Degrees from Winged Horses)
    Posts
    10,435
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    On occasion I get the feeling that OPs have an moment and don’t bother coming back. I have them often enough.
    Tom
    TBLO
  8. #18
    Join Date
    Feb 2013
    India
    Posts
    2,555
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Sahib View Post
    If vector sum of line or phase voltage readings of the generator by OP does not equal zero ie they do not form a closed triangle even approximately, it implies erroneous readings or a break in generator windings.
  9. #19
    Join Date
    Jan 2016
    Earth
    Posts
    6,049
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    +(vab = 25 + 175j) or 175/82
    -(vac = 25 - 175j) or 175/-82
    -(vbc = 0 + 350j) or 350/90
    = 0 + 0j
    something does not compute
    one machine in reverse rotation
    messed up connections
    etc or some combination
  10. #20
    Join Date
    Apr 2009
    Williamsburg, VA
    Posts
    6,042
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I don't understand, if the neutral is kept floating, then aren't any line to neutral voltage readings meaningless?
    If the voltage readings are true, I can't really wrap my head around it either except to speculate that a neutral and a phase are reversed or one generator has its windings in series rather than parallel. I would compare connections to the other six generators that are working fine, try to rule out any obvious errors
Posting Permissions
  • You may not post replies
  • You may not edit your posts
