User Tag List
Page 2 of 2 FirstFirst 1 2
Results 11 to 14 of 14
Thread: RGS/IMC
  1. #11
    Join Date
    Jan 2018
    SE Michigan
    Posts
    122
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    It's thinner wall, different alloy that is much stiffer and and hard. Bending takes more effort. The spring-back after bending is much more.
    Its much more difficult to adjust a bend after the initial bend, and is likely to kink if you try and adjust it too much.
    If your using a machine to bend, the degrees of bend need adjustment as the spring back is much greater.
    Threading is similar. You need sharp dies, plenty of oil, and more force.
    Its less durable from a corrosion standpoint, especially for underground runs.
    It's best for long overhead runs, with minimal bends, where weight and cost are factors.
  2. #12
    Join Date
    Feb 2003
    Illinois
    Posts
    23,908
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by ActionDave View Post
    It is harder and more brittle, impossible to thread without new dies, and sucks to bend.
    And that in the real world, amounts to a higher labor rate than rigid, even though the labor manuals show IMC as lower based only on the weight.
    Don, Illinois
    (All code citations are 2017 unless otherwise noted)
  3. #13
    Join Date
    Apr 2009
    Williamsburg, VA
    Posts
    6,042
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by nhee2 View Post
    Other than that, though, it's great?
    LOL!
    On the other end of the suck Spectrum, there is ENT on reels. in cold weather, it has a nasty tendency to snap unexpectedly, and the loose end will recoil and either hit you in the face or the groin. You have to hand straighten the stuff about every 6 in to get a reasonably straight run.
    this results in a "straight run" of conduit with a million little one and two degree kicks in it. Also, about one-in-five fittings will snap or crack when inserting ENT into them. if you're installing the stuff in cold weather, you might as well add an extra 15 or 20% to your materials cost.
    And it has to be strapped every 3 ft, which means if you're running it in trusses on 24 inch centers you have to strap it to every truss. and if you put a butt connector in the middle of a curve, I guarantee your fish tape will hang on it
  4. #14
    Join Date
    Jul 2017
    Southern Minnesota
    Posts
    20
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I've run many many many feet of 1/2-2" IMC and never really had any issues with it. I am surprised to see some people dislike it so much. I actually usually buy it over rigid unless I want the added protection from physical damage. My only real gripe is my shop doesnt have the correct 555 bender die for 1 1/2 and 2" and the rigid one ripples the 90s and it pisses me off.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
