User Tag List
Results 1 to 10 of 10
Thread: "Edison" style bulbs and PAR bulbs
  1. #1
    Join Date
    Apr 2018
    Minneapolis,Minnesota,U.S.
    Posts
    5
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I know it is a stupid question, but I really wanna figure this out. The thing is that I have met someone want to buy bulbs, he want "Edison" style bulbs (traditional bulbs), not PAR bulbs. So what's the difference between Edison style bulbs and PAR bulbs? I guess all "Edison" style bulbs are transparent, able to see the fuse clearly. Am I right? If my expression is unclear, please indicate.
    Last edited by rbalex; 05-03-18 at 09:12 AM. Reason: Removed signature advertising
  2. #2
    Join Date
    Dec 2012
    Placerville, CA, USA
    Posts
    20,299
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by syhdeejey View Post
    To me Edison style bulbs are what are formally designated as Type A, roughly spherical with a cylindrical neck and screw base. Traditionally seen in table and floor lamps with shades and in fixtures that either expose the whole bulb or have a crude reflector behind the bulb.
    PAR, on the other hand, are roughly conical, with a rounded or flat face as the based of the cone and a very good reflective surface on the cone portion.
    More specifically PAR stands for Parabolic Aluminized Reflector. The parabolic part means that the reflector will take all light rays striking it from a filament located at the focal point and send them out directly along the axis of the bulb.
    In a recessed fixture an A type bulb will loose much of its light output to the collar on the inside of the fixture and will give a very wide light distribution. A PAR bulb will send most of its light directly out of the fixture at an angle which will depend on the nominal angle of the bulb, ranging from spot through narrow flood to wide flood.
    In newer lighting design terminology an "antique" Edison bulb is clear with a long visible reddish-yellow filament, looking like the carbon filament in the earliest bulbs invented by Thomas Edison. Other type A bulbs may be frosted or otherwise hide the filament to give a softer light distribution. And give a much whiter light.
    You need to find out which meaning of the term your customer is using.
  3. #3
    Join Date
    Apr 2009
    Williamsburg, VA
    Posts
    6,042
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Welcome to The Forum. To me, Edison is a type of base (medium), not a style of lightbulb. in the context you presented though, I would assume the customer wants 'round bulbs', not floodlights or directional.
  4. #4
    Join Date
    Jun 2004
    Cherry Valley NY, Seattle, WA
    Posts
    5,748
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    Does he want to run them with DC too ?
    Ethan Brush - East West Electric. NY, WA. MA
    "You can't generalize"
  5. #5
    Join Date
    Jun 2003
    Hawthorne, New York NEC: 2014
    Posts
    4,708
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Well, it gets a little more complicated than that. Have a look here for everything you need to know. http://www.ledwatcher.com/light-bulb...pes-explained/
    -Hal
  6. #6
    Join Date
    Feb 2003
    Bremerton, Washington
    Posts
    8,175
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    And there are some very nice Edison style LED lamps available
    Moderator-Washington State
    Ancora Imparo
  7. #7
    Join Date
    Feb 2003
    Minnesota
    Posts
    7,134
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by hbiss View Post
    -Hal
    Hal, you ole rabble rouser! "Edison" is only mentioned once in your referenced link.
    Personally, I have come to use "Edison" only in reference to the type of base. In your linked reference that is the E26 screw shell.
    Another Al in Minnesota
  8. #8
    Join Date
    Apr 2018
    Posts
    5
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks, gentlemen. Actually, he is not my customer. I saw his question and I'm curious about the difference between "Edison" style bulbs and PAR bulbs. I marked the article and will read it.
  9. #9
    Join Date
    Dec 2007
    NE Nebraska
    Posts
    41,314
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Edison is typically referring to the base type not the lamp type.
    There are many lamp types that use an Edison base - including some PAR type lamps.
    There is even Edison base plug fuses that use the same base as Edison base lamps.
    I live for today, I'm just a day behind.
  10. #10
    Join Date
    May 2005
    Richmond, Virginia
    Posts
    25,430
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by kwired View Post
    Very handy for troubleshooting short circuits.
    Code references based on 2005 NEC
    Larry B. Fine
    Master Electrician
    Electrical Contractor
    Richmond, VA
Posting Permissions
  • You may not post replies
  • You may not edit your posts
