User Tag List
Page 2 of 2 FirstFirst 1 2
Results 11 to 12 of 12
Thread: Ham Radio Towers & NEC Bonding Requirements.
  1. #11
    Join Date
    Mar 2008
    Michigan. It's a beautiful penninsula, I've looked around.
    Posts
    10,383
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    If the antenna is fed with coax, the radials will be bonded by virtue of the shield on the coax being bonded, since the radials are going to be connected to the shield at the feed point.
    The radials are part of the antenna. Not all radials are on the ground. 'Ground plane' antennas have elevated radials. The radials on or in the dirt are treated the same way as the ones that are high off the ground.
    Cheers and Stay Safe,
    Marky the Sparky
  2. #12
    Join Date
    Mar 2008
    Posts
    10,383
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by dereckbc View Post
    Now here is what is really scary and most Hams have been told to do. They sink a Ground Rod or two where the Coax enters and fail to bond them to the GES.
    Thankfully, there is someone that is doing a great job of setting them straight on the ham radio forum QRZ.
    They don't all go down without a fight, though.
    Marky the Sparky
Posting Permissions
  • You may not post replies
  • You may not edit your posts
