Page 1 of 2 12 LastLast
Results 1 to 10 of 13
Thread: POOL QUESTIONS
  1. #1
    Join Date
    Dec 2012
    Farmingham, MA
    Posts
    136
    POOL QUESTIONS
    I am not sure about this situation but here goes . This concerns a in ground pool that was installed at least 25 years ago. The concrete pad around the pool has been painted to increase its appearance. This is the area from edge of pool to about 4' away .
    Can some one comment on the painted concrete if it would violate code and why ? Do most towns reinspect pools when buying or selling a home with a pool ? I have never wired a in ground pool and cannot find any info on my concerns.
    Thanks for any help here.
  2. #2
    Join Date
    Dec 2006
    Chapel Hill, NC
    Posts
    33,565
    The painted concrete should have no effect on the code. Why would you worry about that?
    They say I shot a man named Gray and took his wife to Italy
    She inherited a million bucks and when she died it came to me
    I can't help it if I'm lucky
  3. #3
    Join Date
    Apr 2009
    Williamsburg, VA
    Posts
    5,438
    There is no NEC violation. The only things you have to worry about is it being a possible slip Hazard, and if it was put on correctly... You'll know if it starts peeling off in 6 months the surface wasn't prepped correctly.
  4. #4
    Join Date
    May 2014
    AZ
    Posts
    2,423
    Quote Originally Posted by Dennis Alwon View Post
    because putting an insulator over the top of the conductor could break equi-potential, which is the requirement (via bonding). how is this different than say wearing rubber crocs? the diff is, NEC requires the surface materials to be bonded to provide equi-potetntial of any faults, vs NEC says nothing about crocs.
    in reality, its a kludge of sorts. concrete needs bonded mesh, pavers need just a wire under the pavers. that section should just be labeled "best effort, hopefully you don't get shocked".
  5. #5
    Join Date
    Apr 2003
    Fort Collins, Colorado
    Posts
    1,680
    Quote Originally Posted by FionaZuppa View Post
    25 years ago?
    Ron
  6. #6
    Join Date
    May 2014
    AZ
    Posts
    2,423
    Quote Originally Posted by rcarroll View Post
    25 years ago?
    ... if that decking is that old, which would make the OP question kinda moot in context of NEC.
  7. #7
    Join Date
    Dec 2012
    Placerville, CA, USA
    Posts
    19,517
    The Op's question seems to me to be whether the code can require that an equipotential grid be somehow made to include the surface of an insulator. I say it plainly cannot.
    The principle underlying the concept of an equipotential grid is that all electrically conductive surfaces be held at the same electrical potential. The NEC explicitly refers, for example, to metal surfaces within a specified distance from the pool, not any and all surfaces.
    If you argue that the insulating membrane might be damaged, I note that the other side of the membrane is probably part of the equipotential grid, so no harm on that front.
  8. #8
    Join Date
    Mar 2014
    Park Ridge, NJ
    Posts
    88
    If this a commercial/public pool not a residential backyard pool, the deck surface must be non-skid.
    We have painted concrete decks on residential pools to spruce them up. The product I have used is a non-skid finish. Just common sense, any pool deck surface to be painted should be non-skid.
    Prepped properly, it can last 3 + years. It's water based and easy to work with.
    If there is a concern the pool is not properly bonded, call a certified company to test for it.
    Public pools in New Jersey require bonding certification I'm pretty sure every 3 years.
    We have found ladder and rail sockets will corrode quickly (usually aluminum) and fail for bonding. We use either bronze or stainless sockets for longevity.
  9. #9
    Join Date
    Dec 2007
    NE Nebraska
    Posts
    37,901
    Doesn't the shell of concrete pools get painted all the time?
    Even if painted there are capacitive effects, but if everything on concrete side is properly bonded there is still no voltage gradients that will be subject to capacitive coupling to users of the pool, because pool water is also supposed to be bonded and everything within reach of users is at same potential - which is the whole point of equipotential bonding.
    A little like saying something metal that is plastic coated wouldn't be allowed in the pool area even though the metal is bonded. Not familiar enough with pools to be any more specific then that.
    I live for today, I'm just a day behind.
  10. #10
    Join Date
    Mar 2014
    Park Ridge, NJ
    Posts
    88
    kwired
    There a couple of choices for finishes on concrete pools. There is paint and there is as what is termed in my trade, a plaster finish, which is a cement based coating.
    Painted pools are generally painted every 3-4 years. This is mainly because the paint chemical content is not what is was in the past. Paint is now water based and don't last the 6+ years as in the past. Some public pools, seasonal mind you, are on a schedule to paint every 3 years and maybe sandblast and start all over every 6.
    Plastered pools can last as long as 15 years before resurfacing.
    There are pool deck products that are a combo of plastic and metal and must be bonded. Saftron is a company making ladders and rails of plastic that do not require bonding. However, the escutcheons/cups must be bonded if aluminum, bronze or stainless. There are plastic cups but the bolts are stainless. I've never used these as they look cheap to me.
    As you mentioned the pool water must be bonded. There are few products available to meet the code. Surprisingly or surprisingly, not 100% of inspectors have checked for water bonding on my new builds. We of course, have been bonding the water as per code.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
