User Tag List
Results 1 to 5 of 5
Thread: Commercial Projects: When are permits needed?
  1. #1
    Join Date
    Oct 2010
    Posts
    19
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Hi everyone.
    Is there a single source (nationally) that can give me information on what kind of work require a permit? Looking at a 1-for-1 fixture change out in a commercial space and trying to understand if I need a licensed electrician to pull a permit for this work.
    Any help is appreciated.
  2. #2
    Join Date
    Feb 2003
    Fl
    Posts
    17,480
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    The requirements are by local and state rules, there is no National standard.
    Roger
    Join Date
    Dec 2007
    NE Nebraska
    Posts
    39,142
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Roger is correct - such rules vary from one place to another. If the property across the street from you happens to be in a different jurisdiction they could have a different rule then what applies to you for what you are asking about. Your answer is dependent on who the AHJ is at your location.
    I live for today, I'm just a day behind.
  4. #4
    Join Date
    Jun 2016
    Tampa, FL, USA
    Posts
    2,024
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    That would be a dream come true .
    I do work in three counties. One of the counties actually has 13 different jurisdictions. Each of the 13 has their own permit office, forms, rules, and inspectors. I would just like to have one jurisdiction per county. (One of three does have one jurisdiction, the last one has four.) I know having uniform rules across the entire state is a pipe dream.
  5. #5
    Join Date
    Feb 2007
    USA
    Posts
    5,808
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Coppersmith View Post
    CA technically has the same rules for permits across the State , enforcement is a whole different item.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
