User Tag List
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 17
Thread: Exits Feed from Normal Panel
  1. #1
    Join Date
    Sep 2012
    NJ
    Posts
    2,441
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Have exits feed from normal panel in hospital. There is no ATS feeding panel. Find it a little odd an maybe even against code that they are fed from normal panel. Think it's considered life safety.
  2. #2
    Join Date
    Jul 2003
    New Jersey
    Posts
    27,001
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Are they battery backup?
    Rob
  3. #3
    Join Date
    Dec 2007
    NE Nebraska
    Posts
    40,191
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by infinity View Post
    +1
    I live for today, I'm just a day behind.
  4. #4
    Join Date
    Sep 2012
    NJ
    Posts
    2,441
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Yes, arent all?
  5. #5
    Join Date
    Feb 2003
    Fl
    Posts
    17,563
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by mstrlucky74 View Post
    Yes, arent all?
    No they aren't. If they are battery back up fixtures they have to be fed from the normal branch, they have to be fed from the local lighting circuit.
    Roger
    Join Date
    Dec 2007
    NE Nebraska
    Posts
    40,191
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by roger View Post
    Roger
    Which may or may not be on an emergency panel, local circuit must fail before battery takes over.
  7. #7
    Join Date
    Dec 2010
    Posts
    1,471
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I don't think that is true.
    The more they overthink the plumbing, the easier it is to stop up the drain
  8. #8
    Join Date
    Feb 2003
    Fl
    Posts
    17,563
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by dkidd View Post
    You need to read 700.12(F) then.
    Roger
    Join Date
    Dec 2010
    Posts
    1,471
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Exit signs are not unit equipment.
  10. #10
    Join Date
    Dec 2007
    NE Nebraska
    Posts
    40,191
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Some are some aren't.
    If required to be illuminated during normal power failure, then likely considered part of emergency lighting system, though there are signs that don't even require power these days to be visible in low to no light conditions
Posting Permissions
  • You may not post replies
  • You may not edit your posts
