User Tag List
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 15
Thread: PVC Duct Bank
  1. #1
    Join Date
    Sep 2012
    NJ
    Posts
    2,441
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    PVC Duct Bank
    if i have pvc conduits below grade that are stubbing up into the bottom of switchgear on grade would they transition to rgs or similar when stubbing into the gear. would imagine you cant stub up through grade slab and into gear with pvc. i know spec usually dictates but i was curious of others experience. thanks.
  2. #2
    Join Date
    Dec 2006
    Eastern Oregon
    Posts
    3,716
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Do they let you do site visits to the jobs you bid?
    A picture being worth a thousand words, a site visit and regular talks with foremen would be priceless in your situation.
    To answer your question, stubbing up into gear with pvc is extremely common.
  3. #3
    Join Date
    Jul 2005
    Posts
    907
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    If the specs require it...why do you even ask?
  4. #4
    Join Date
    Sep 2012
    NJ
    Posts
    2,441
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Cow View Post
    Thanks thought one would never stub up into gear with PVC.
  5. #5
    Join Date
    Jul 2005
    Posts
    907
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by mstrlucky74 View Post
    Why?
  6. #6
    Join Date
    Dec 2006
    Eastern Oregon
    Posts
    3,716
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by cdslotz View Post
    Why?
    Because he's an estimator with no field experience, apparently can't ask anyone on site, and he doesn't know his way around the NEC to look for himself?????
  7. #7
    Join Date
    Sep 2012
    NJ
    Posts
    2,441
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    niiiice
  8. #8
    Join Date
    Sep 2012
    NJ
    Posts
    2,441
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Why?
    Because every spec I've read says no PVC within footprint of building...except this one.
  9. #9
    Join Date
    Aug 2004
    Northern illinois
    Posts
    17,394
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    You might be able to get some dispensation to stub UG PVC into floor mounted gear. maybe they would be more amenable to it if you agreed to use sch 80 where it pops up into the gear.
    personally, unless it is a huge amount of money involved, I don't like asking for variations from the spec. I'd be inclined to just run the last few feet of conduit that goes into the gear as rigid.
    most places though, there are conduits that come out of the floor and are exposed and I am not real thrilled with exposed and vulnerable PVC, even when it is in compliance with the code.
    Bob
  10. #10
    Join Date
    Feb 2003
    Illinois
    Posts
    24,012
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Even if you are permitted to use a PVC 90, you have to take a look at the pull to see if it will be likely that the pull rope will cut though the PVC at the 90 and result in damaged conductors. If it will be a short easy pull, not an issue, but it is an issue on long difficult pulls.
    Don, Illinois
    (All code citations are 2017 unless otherwise noted)
Posting Permissions
  • You may not post replies
  • You may not edit your posts
