User Tag List
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 12
Thread: Electric car charger near gas dispenser ??
  1. #1
    Join Date
    Apr 2004
    N. Ft. Myers
    Posts
    16
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    This is a new one for me, Customer wants an electric car charger installed, charger would be out of Class 1 Div.2 but it has a 30' cord reel that will reach the gas dispenser and then some.
    Don't know if anyone has run into this yet.
    R.H.N.
  2. #2
    Join Date
    Aug 2004
    Northern illinois
    Posts
    17,422
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by rhn View Post
    I don't see how a classified area 30 feet away makes any difference. what if it was just a receptacle? how would you prevent someone from plugging an extension cord into it and dragging the other end of the cord into the classified area.
    Bob
  3. #3
    Join Date
    Apr 2004
    N. Ft. Myers
    Posts
    16
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Charger would be mounted 22' from gas dispenser. Charger cord to plug into vehicle is on a 30' reel. Electric car could be parked in the spot on either side of the gas dispenser and plugged in
    R.H.N.
  4. #4
    Join Date
    Aug 2004
    Northern illinois
    Posts
    17,422
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I don't recall any requirements in the code that would prohibit this install. If you don't like it, turn down the work.
    Bob
  5. #5
    Join Date
    Feb 2009
    Durango, CO, 10 h 20 min without traffic from winged horses.
    Posts
    10,035
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Why would someone with an electric car park at a gas pump and drag a cord from a charger station thirty feet away?
    As long as the charger is outside the classified area I don't see a problem.
    If you don't think too good, don't think too much.
  6. #6
    Join Date
    Apr 2004
    N. Ft. Myers
    Posts
    16
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by ActionDave View Post
    It's at a big used car dealership. The gas pump is not on an island like a store, it's just on a concrete pad with parking spaces by it,
    and now they want to be able to charge any PEV's they might get in.
    R.H.N.
  7. #7
    Join Date
    Feb 2009
    Posts
    10,035
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    I still don't see a problem.
  8. #8
    Join Date
    Apr 2009
    Williamsburg, VA
    Posts
    6,042
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Do the electric vehicle charging cords have a handle on them like a gas pump? Something that would open the circuit before disconnecting from the car to prevent arcs? Iow, can one disconnect the charger cord under a load?
    If the answer to that last question is yes, or if arcing is possible, I do not see how you could put the thing within reach of a gas pump, which have every kind of warning known to man about not creating static discharges, turn engine off while fueling, Etc.
    I would put the electric vehicle charging station elsewhere, or shorten the cord so that it cannot be near the gas pump. No NEC basis for this, just a design consideration with safety in mind.
  9. #9
    Join Date
    Jul 2005
    Tennessee
    Posts
    16,578
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    If I was going to worry about the arc at an electric vehicle, I'd be scared to death every time someone started their conventional engine sitting at the gas pump
    I would think the 18" "envelope" on the dispenser classification should minimum any hazard.
    Just watch out for the guy leaning up against the gas pump as he takes his afternoon smoke break.
    At my age, I'm accustomed to restaurants asking me to pay in advance, but now my bank has started sending me their calendar one month at a time.
  10. #10
    Join Date
    Apr 2007
    Berkeley, CA
    Posts
    1,822
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by JFletcher View Post
    Yes, to disconnect a J1772 connector from an EV, you push a button to disengage a simple mechanical lock. That button push also sends a signal to the EV to stop charging. So when you pull the connector out, it should not be under load.
    Cheers, Wayne
Posting Permissions
  • You may not post replies
  • You may not edit your posts
