User Tag List
Page 2 of 2 FirstFirst 1 2
Results 11 to 14 of 14
Thread: LED Tape under cabinet install
  1. #11
    Join Date
    May 2005
    Richmond, Virginia
    Posts
    24,775
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by sw_ross View Post
    Anyone ever have problems with the 3M adhesive on the tape light?
    I carry a bottle of contact cement for questionable adhesion, the kind you apply to both sides and allow to dry before assembly.
    Code references based on 2005 NEC
    Larry B. Fine
    Master Electrician
    Electrical Contractor
    Richmond, VA
  2. #12
    Join Date
    Oct 2015
    US
    Posts
    877
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    I don't trust the tape I usually install in some sort of channel like this. If you can. See all those little burn marks on the bottom of the cabinets those were actually from the old 12v halogen bulbs. I replaced them with these used the same wiring just Changed fixtures and driver
    Sent from my SM-G950U using Tapatalk
  3. #13
    Join Date
    Oct 2015
    US
    Posts
    877
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Sorry so I screw these to bottom of cabinets and the tape sticks pretty good to the aluminum I usually wipe them down with some alcohol swabs before and I never had a problem
  4. #14
    Join Date
    Apr 2003
    Posts
    107
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by nickelec View Post
    This is what I use as well, just yesterday in fact.
    Armacost Lighting has some connections that are very solid.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
