User Tag List
Results 1 to 3 of 3
Thread: next higher size???
  1. #1
    Join Date
    May 2013
    Tujunga, CA
    Posts
    449
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    next higher size???
    Hi
    I am supplying a 120' away sub panel l thru a set of #6 thhn, cu in an apartment building.
    Question is,
    can use 70A ocpd for the feeder main ; according to next-larger size rule ?????
    Also,
    70A ocpd for the feeder main; What size copper wires can be used to feed that apartment sub panel. ???????
    Thank you
  2. #2
    Join Date
    Jul 2005
    Tennessee
    Posts
    16,182
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    215.2 requires that your feeder conductor have the amapcity to supply the load so your #6 THHN would be good for a 65 amp loadassuming 75° terminations. If your load does not exceed 65 amps, you are good with a 70 amp overcurrent device.
    At my age, I'm accustomed to restaurants asking me to pay in advance, but now my bank has started sending me their calendar one month at a time.
  3. #3
    Join Date
    Dec 2007
    NE Nebraska
    Posts
    39,120
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by augie47 View Post
    I second that and add that if your feeder is NM cable - you are limited to 60C ampacity.
    I live for today, I'm just a day behind.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
