User Tag List
Page 2 of 2 FirstFirst 1 2
Results 11 to 14 of 14
Thread: How to Comply w/NEC 2017 690.11 Arc-Fault Circuit Proection (DC)-Strings > 3 Modules?
  1. #11
    Join Date
    Mar 2003
    Vermont
    Posts
    1,959
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I'm told the latest inverters provide AF protection?
    ~RJ~
  2. #12
    Join Date
    Oct 2009
    Austin, TX, USA
    Posts
    10,466
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by romex jockey View Post
    ~RJ~
    Many of them, yes.
  3. #13
    Join Date
    Nov 2015
    CA, USA
    Posts
    717
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    If you really want to get into the nuts and bolts UL standard 1699B used to list PV arc fault equipment describes the type of arc fault that is protected against and it is series only.
    Series arc faults were determined to occur more often than parallel arc faults and to end a parallel arc fault you have to open the source side. Since that means module level disconnects no one wants to go there just to stop parallel arc faults. Disconnecting the load can make parallel arc faults worse so it's a conundrum. Also, parallel arc faults are just developing L-L or L-G faults and those have at least limited protection from OCPD.
  4. #14
    Join Date
    Mar 2003
    Vermont
    Posts
    1,959
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    A series hot spot aka-arc is literally 1/2 my service calls.
    As to 690.12, it makes sense , given DC's ionization qualities vs. AC
    ~RJ~
Posting Permissions
  • You may not post replies
  • You may not edit your posts
