User Tag List
Results 1 to 4 of 4
Thread: Where can I find in the Florida Building Code 2017 the illumination level required
  1. #1
    Join Date
    Jan 2017
    Florida
    Posts
    16
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Hello,
    Where can I find in the Florida Building Code 2017 the illumination level required (normal power and egress) for: residential building corridors, elevator lobby, electrical room, pump room, lobbies, and building exterior?
    Thank you very much
  2. #2
    Join Date
    Feb 2003
    New York, 40.7514,-73.9925
    Posts
    4,819
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I would check the Building Code Section 1008
    https://codes.iccsafe.org/public/doc...eans-of-egress
    Ron
  3. #3
    Join Date
    Feb 2015
    Lakeland fl
    Posts
    1
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I believe that’ll be in the energy code
    Sent from my iPad using Tapatalk
  4. #4
    Join Date
    Dec 2010
    Posts
    1,497
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by jeffrey.morrison.9406 View Post
    No it isn't.
    Egress levels are in NFPA 101 or IBC 1008 as mentioned. I recall there is a minimum of 10 footcandles normal lighting in occupiable spaces. There are requirements for elevator pits. Otherwise IES has recommendations.
    The more they overthink the plumbing, the easier it is to stop up the drain
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
