User Tag List
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 14
Thread: Same xfrmr feeding 2 diff swiches
  1. #1
    Join Date
    Sep 2012
    NJ
    Posts
    2,359
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Scenario, same xfrmr feeding two different switches.
    Building 22 switch being feed with 4 sets of #500 & 1 #1/0
    Building #23 switch being feed with 5 sets of the same size wires.
    To me it looks( the dot) like they are calling for either feeder to be tapped. I know you can’t run the sets for both switches from the xfrmr, meaning it can’t directly feed them so it has to be a tapped, correct? Could one one Ilsco tap blocks for this application? Seems a bit tricky. Need a big tap box as well. Thanks.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	20338   Click image for larger version.
  2. #2
    Join Date
    Aug 2004
    Northern illinois
    Posts
    17,054
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by mstrlucky74 View Post
    I don't see why the connection cannot be made right at the transformer. Whether it is a legal tap or not is something else that IMO is not dependant on whether the connection is made at the transformer..
    Bob
  3. #3
    Join Date
    Feb 2003
    Illinois
    Posts
    23,908
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    You can have multiple sets of conductors running from a transformer. Is the transformer located outside? If not, you will be limited by the 25' rule in 240.21(C)(6). If the transformer is outside the rule in 240.21(C)(4) will apply permitting unlimited conductor length as long as the installation complies with all of the rules in that subsection.
    Don, Illinois
    (All code citations are 2017 unless otherwise noted)
  4. #4
    Join Date
    Sep 2012
    NJ
    Posts
    2,359
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by petersonra View Post
    9 sets leaving xfrmr?? Where the hell would all the conductors terminate?
  5. #5
    Join Date
    Aug 2004
    Northern illinois
    Posts
    17,054
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I didn't say it was practical just legal. Besides most of the time you can get stackable connectors
    Bob
  6. #6
    Join Date
    Feb 2003
    Illinois
    Posts
    23,908
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    T&B has various adapters for transformer connections that permit up to 16 sets of conductors.
    Don, Illinois
  7. #7
    Join Date
    Sep 2012
    NJ
    Posts
    2,359
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by don_resqcapt19 View Post
    Wow. How can I get a pic of how those connections look inside xfrmr? Thanks
    Sent from my SM-G955U using Tapatalk
  8. #8
    Join Date
    Jun 2004
    Cherry Valley NY, Seattle, WA
    Posts
    5,048
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    You could use something like this with one on each side of the spade for 16 terminals.
    Attached Images Attached Images
    Ethan Brush - East West Electric. NY, WA. MA
    "You can't generalize"
  9. #9
    Join Date
    Sep 2012
    NJ
    Posts
    2,359
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by electrofelon View Post
    But still don't understand how it's possible to come out of the xfrmr with 16 sets of 4". Does not seem like there would be enough room for all those conduits/flex to terminate on the enclosure.
  10. #10
    Join Date
    Sep 2012
    NJ
    Posts
    2,359
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Sorry I have 9 sets 4".
Posting Permissions
  • You may not post replies
  • You may not edit your posts
