User Tag List
Page 3 of 3 FirstFirst 1 2 3
Results 21 to 27 of 27
Thread: Scissor Lift Static Shock
  1. #21
    Join Date
    Mar 2017
    Florida
    Posts
    96
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I stripped some 10AWG copper and wrapped it around the frame and it lays on the floor pretty stealthy under the stepladder in the rear. So far no shock but I have to investigate further.
  2. #22
    Join Date
    Jul 2017
    Western Grove, AR Newton County
    Posts
    36
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Silicone Rubber Strips for Static Grounding
    I ran into this on our Forklifts and Scissors Lifts. As others have said, dragging a chain or copper wire would work since it is a rental. Others may be reading this that are having trouble on their own equipment. I purchased Shielding High-Temperature Silicone Rubber Strips through McMaster. It solved the problem. You could use this on a Rental if you used some sort of removable Clamp.
  3. #23
    Join Date
    Feb 2013
    India
    Posts
    2,548
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by 2Broke2Sleep View Post
    Shocking has to do with ground resistance also: it has to be below a certain limit to avoid shock even with your above arrangement.
  4. #24
    Join Date
    Jan 2014
    chicago, il, USA
    Posts
    424
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I've seen this happen on older lifts that use diode logic for controlling the hydraulic solenoids. I'm assuming that since they're rental lifts they're newer and don't use diodes but it's something to consider. I have personally experienced this, the shock would occur when holding the handle and the cage. You would received the shock as soon as you stopped operating the lift. I figured one of the diodes was bad, this caused a flyback from the magnetic field collapsing.
    The world is round, you will get there no matter what path you take.
  5. #25
    Join Date
    May 2018
    Cincinnati ohio
    Posts
    10
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by SceneryDriver View Post
    Rubber tires on carpeted surface will build up a static charge. A piece of bare #12 copper wire attached to the lift's frame and trailing on the floor may be enough to dissipate the charge, maybe not.
    SceneryDriver
    After driving a scissor lift on carpet on the 38th floor of a high rise, the static shock was strong enough to singe hair.
  6. #26
    Join Date
    Aug 2009
    Alaska
    Posts
    24
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    On a hanger remodel job, the flooring contractor resurfaced a floor with epoxy right after the demo phase because it fit with their schedule. The general had to put down plastic 5 mil then put plywood on top of that. We were arcing up to 1.5 inches from static. That job was 12 years ago and I still shy away from touching metal when I'm in a lift. BTW, some older aircraft like a DC-6 have leather straps for grounding.
    Back on your heads boys, break is over.
  7. #27
    Join Date
    Mar 2016
    The Motor City, Michigan USA
    Posts
    971
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by jimo144 View Post
    ... You could use this on a Rental if you used some sort of removable Clamp.
    For the infinitesimal amount of money involved, you could install it permanently and do the next renter a small favor.
    Quote Originally Posted by pitkas View Post
    ... BTW, some older aircraft like a DC-6 have leather straps for grounding.
    Sure, why not? Leather is skin, and skin is conductive. Come to think of it, I probably have a few old leather belts kickin' around that are overdue to be repurposed.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
