User Tag List
Page 2 of 5 FirstFirst 1 2 3 4 ... LastLast
Results 11 to 20 of 49
Thread: Multiconductor Cable Ampacity
  1. #11
    Join Date
    Dec 2006
    Chapel Hill, NC
    Posts
    34,153
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    Why do you have to use a cable?
    They say I shot a man named Gray and took his wife to Italy
    She inherited a million bucks and when she died it came to me
    I can't help it if I'm lucky
  2. #12
    Join Date
    Feb 2013
    India
    Posts
    2,555
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Dennis Alwon View Post
    To preclude the possibility of voltage unbalance, due to inadvertent, unequal separation of individual phase wires,at pump motor input.
  3. #13
    Join Date
    Aug 2004
    Northern illinois
    Posts
    17,070
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Sahib View Post
    Huh??
    Bob
  4. #14
    Join Date
    Aug 2004
    Northern illinois
    Posts
    17,070
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    See post #5 where I asked the same question. You can get a supply house to twist the conductors into a bundle for you if you want.
    Bob
  5. #15
    Join Date
    Dec 2007
    NE Nebraska
    Posts
    39,161
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Is this 1-1/4 RGS actually used as a raceway or is it just a sleeve? Fill requirements don't apply to a sleeve, but are worth some consideration when there is significant length to them and how difficult it may be to get the cable in there.
    If 75C terminations are involved a 100 HP 460 volt motor must have 2/0 copper minimum conductor. You didn't say what the voltage is.
    My motor slide calculator does show 1 AWG if it were a 575 volt motor, but you did mention you need 124 ampacity which is NEC FLA for 460 volt motor, NEC requires minimum ampacity of 125% of that though in most applications so that puts required conductor ampacity at 155. Adjustments if required can start at the 90 C rating though.
    I live for today, I'm just a day behind.
  6. #16
    Join Date
    Feb 2003
    Seattle, WA
    Posts
    19,331
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Thanks for the comments. Here are a few responses.
    • The motor will run at 480V 3 phase.
    • I don't have to use a cable. But it gives me 53% of the internal area of the conduit, as opposed to 40%.
    • The RGS runs up from a gutter about 12 inches. It turns left via an elbow thingy (I don't know its name), and continues out of the range of my photo.
    • I think I could use the conduit as an EGC.
    • The selection of 100 HP is a design choice by the mechanical engineer. I asked him yesterday what the impact might be if I said he had to use a smaller motor. He was not pleased.
    • The power source (i.e., the other end of the RGS run) is a very old unit substation. I doubt it would have, or could get, 90C terminations.
    • I haven't looked into compact conductors yet.
    • I am told the run is closer to 650 feet than 500 feet. I would need a 2/0 just to keep VD below 3% anyway.
    Charles E. Beck, P.E., Seattle
    Comments based on 2017 NEC unless otherwise noted.
  7. #17
    Join Date
    Feb 2003
    Seattle, WA
    Posts
    19,331
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Here is another approach: Table 430.22(E). The application is a sump pump, and the on/off cycles are driven by water level. I watched the existing system operate a couple weeks ago. It seemed to me that it took less than 2 minutes for the pump to bring the water level from the "on" setpoint level to the "off" setpoint level. Under worst case conditions, I am made to understand that the pump would cycle on every 11 minutes or so. We are looking at ways to extend that, so that the pump doesn't experience that frequent a start/stop cycle.
    With that said, I think I can use the "intermittent duty" 15 minute rated value of 85%. So my minimum ampacity would be 85% of 124, or 106 amps. A #2 would do that job. I would still have to deal with VD issues, but this could resolve the "conduit fill" problem.
    Any comments?
  8. #18
    Join Date
    Aug 2004
    Northern illinois
    Posts
    17,070
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by charlie b View Post
    My handy dandy chart says that a 480V 100 HP motor requires conductors with an ampacity of 124*125% or 155 Amps. That would give you a 2/0. Even if you can use an allowance for lower duty cycle that would only get you to a 1/0 conductor.
    A 600V motor only needs 99*125% worth of ampacity or 124 Amps. A #1 wire would do.
    No reason you could not splice on some larger conductors before terminating it at the old substation.
    Bob
  9. #19
    Join Date
    Feb 2003
    Seattle, WA
    Posts
    19,331
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by petersonra View Post
    How's come we are so far apart on this calculation?
  10. #20
    Join Date
    Feb 2003
    Seattle, WA
    Posts
    19,331
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Aside: Is "RMC" the current and more appropriate name for what I have been calling "RGS"?
Posting Permissions
  • You may not post replies
  • You may not edit your posts
