User Tag List
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 11
Thread: On half of a switchleg is dimming after a few hours??
  1. #1
    Join Date
    Oct 2017
    Manteca,Ca
    Posts
    8
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    This is a pretty big service area. There are around 80 lights,
    4 trunklines with 2 switchlegs and one emergency circuit.
    Each switchleg has its own roomcontroller.
    So half one switchleg (which is one whole trunkline ) dims after being on for about 5 hours.if u turn off the switch and let the lights rest for a while they will turn bright again for a while This problem only started last week and the buildiny has been up and running wit tennants for 4 months already.
    Just an FYI these lights do not have the dimming wires attached . They are capped off and no;38,^ used.. any ideas?
    Sent from my SM-N950U using Tapatalk
  2. #2
    Join Date
    Dec 2006
    Chapel Hill, NC
    Posts
    34,135
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    Sounds like a loose connection somewhere that is affected by the heat from the load
    They say I shot a man named Gray and took his wife to Italy
    She inherited a million bucks and when she died it came to me
    I can't help it if I'm lucky
  3. #3
    Join Date
    Oct 2017
    Manteca,Ca
    Posts
    8
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Dennis Alwon View Post
    I was thinking the same thing. Good good thing its all of the lights. That means its near the beginning of the run
  4. #4
    Join Date
    Dec 2006
    Chapel Hill, NC
    Posts
    34,135
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    Could be the switch itself
  5. #5
    Join Date
    Apr 2009
    Williamsburg, VA
    Posts
    6,042
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    That was my first thought. I've seen a few cases were residential grade switches were used in commercial, 1200 Watts worth lighting put on a 600-watt dimmer, 20a of lighting on a 20a breaker, etc.
    If the switch is the culprit, it will probably be half melted already.
    Electricians do it until it Hertz!
  6. #6
    Join Date
    Feb 2007
    USA
    Posts
    5,808
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    No Dimming hooked up?
    How did you get that past Title 24 lighting controls?
  7. #7
    Join Date
    May 2018
    bamenda,cameroon
    Posts
    3
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    hi, i think that there is a problem with the connections too. you can also call the manufacturer if the problem persist. maybe the arrangement made in your installation at some point may not be recommended.
    but check your connections again.
  8. #8
    Join Date
    Feb 2006
    Jersey
    Posts
    2,397
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Sierrasparky View Post
    glad I don't live in california.
    " I'm at a crucial part of my painting "...........Monika Danneman
  9. #9
    Join Date
    Apr 2008
    Ann Arbor, Michigan
    Posts
    7,482
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    180520-2452 EDT
    Obviously some voltage measurements should be made.
  10. #10
    Join Date
    Oct 2017
    Manteca,Ca
    Posts
    8
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Hey everyone. The problem was a bad driver at the very beginning of the run. Had a field day diagnosing it but it was all worth it in the end
Posting Permissions
  • You may not post replies
  • You may not edit your posts
