User Tag List
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 12
Thread: Defrost timer mounted inside walk-in freezer?
  1. #1
    Join Date
    Jun 2006
    NoDak
    Posts
    414
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Do you see/have problems with the idea of mounting the time clock in the freezer?
    This walk-in is located outside and is detached from the building by about 3 feet.
    It would greatly simplify the installation if there wasn't a problem with doing this.
    Thanks!
  2. #2
    Join Date
    Sep 2008
    UK
    Posts
    12,703
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by sw_ross View Post
    Thanks!
    Will the timer work at freezer temperatures? Our domestic freezer runs at -25C which is about -13F. Not sure how or if electrical/electronic components would survive that.
  3. #3
    Join Date
    Dec 2007
    NE Nebraska
    Posts
    40,165
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Electric components will be fine. Lubricants on mechanical components is what may have issues in low temp extremes.
    That said timer motor will generate some heat, and will be a little warmer inside the enclosure then it is outside. That alone should help prevent condensation within that enclosure.
    I live for today, I'm just a day behind.
  4. #4
    Join Date
    Jun 2006
    NoDak
    Posts
    414
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks!
    Quote Originally Posted by kwired View Post
    Thanks for the help!
  5. #5
    Join Date
    Sep 2008
    UK
    Posts
    12,703
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    The timers we commonly use are specified as -10C to +50C.
    The OP needs to check the spec on his.
  6. #6
    Join Date
    Dec 2007
    NE Nebraska
    Posts
    40,165
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Besoeker View Post
    I agree. The ones he was talking about in another thread likely are designed to be used in similar temp extremes.
  7. #7
    Join Date
    Jun 2006
    NoDak
    Posts
    414
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    It's a Paragon, model # 8145-20.
    I'll look at it closer when I get to the job today regarding any temp limitations.
  8. #8
    Join Date
    Jul 2013
    Moab, UT USA
    Posts
    271
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks!
    Its better practice not to do so because things can often get very wet inside walk in freezers under various operating conditions in temperate zones, and with varying quality of moisture sealing practices.Also, its better not to have that clock where non-professionals can lay hands on it, again with it being potentially quite wet.
    Most modern condensing units are set up to have the timer mounted inside the cabinet. This means one control conduit run from the CU to the Evaporator which you should need in most cases anyway with 240V electric defrost systems.
    Microwave Radiation Dangers should be openly discussed
  9. #9
    Join Date
    Mar 2016
    The Motor City, Michigan USA
    Posts
    1,069
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    ... timer motor will generate some heat, and will be a little warmer inside the enclosure then it is outside. That alone should help prevent condensation within that enclosure.
    "Some": 5 watts, maybe, which won't be nearly enough to prevent condensation, nor to keep the mechanical parts up to -10°C. (if applicable)
  10. #10
    Join Date
    Apr 2003
    Planet macmikeman
    Posts
    3,490
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    If you can mount it on the roof of the cold box that is what I would do. Make a unistrut brace for it out of 2 pieces of strut and a 90 degree strut connector. Bolt one leg of the strut angle to the roof of the box and let the other end stand straight up. Support the timer off of that. Run liquid tite down into the box to the fan coil.
    85deg. an Sunny today.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
