User Tag List
Results 1 to 6 of 6
Thread: Recessed Mounted Panel
  1. #1
    Join Date
    Sep 2012
    NJ
    Posts
    2,441
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Anyone happen to have pics of one mounted prior to wall being installed? Would like to see it mounted to studs etc. Thanks.
  2. #2
    Join Date
    May 2005
    Richmond, Virginia
    Posts
    24,775
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    You mean like these?
    Click image for larger version.
ID:	20373 Click image for larger version.
    Code references based on 2005 NEC
    Larry B. Fine
    Master Electrician
    Electrical Contractor
    Richmond, VA
  3. #3
    Join Date
    Sep 2012
    NJ
    Posts
    2,441
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks Larry. Thought strut was sometimes used for recessed in commercial application.....not sure why it would be used if one could just attached to studs.
  4. #4
    Join Date
    Jul 2005
    Tennessee
    Posts
    16,447
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    A lot of variables... pictured, I believe, are load centers which fit most residential stud spacing and depth.
    Commercial panelboards are often wider and deeper and stud centers vary. Strut is not uncommon on commercial.
    At my age, I'm accustomed to restaurants asking me to pay in advance, but now my bank has started sending me their calendar one month at a time.
  5. #5
    Join Date
    Jul 2003
    New Jersey
    Posts
    27,001
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    We mount the commercial panels on strut all of the time before the wall goes up. Usually the carpenter will layout the floor track and we'll use that to get our measurements. We'll allow 5/8" or 1 1/4" past the edge of the track depending on whether it's one or two layers of Sheetrock. Not sure if I have any photo's.
    Rob
  6. #6
    Join Date
    Dec 2007
    NE Nebraska
    Posts
    40,191
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by mstrlucky74 View Post
    Wall details are a big key in what you may or may not be able to do.
    If you are mounting a panel before the wall is built around it you need something other then the wall to mount it on, as well as accurate details of where the wall will be located so you place it in the right position.
    I live for today, I'm just a day behind.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
