User Tag List
Page 1 of 5 1 2 3 ... LastLast
Results 1 to 10 of 44
Thread: Electric Water heater wifi controlled
  1. #1
    Join Date
    Mar 2006
    Essex, New Jersey
    Posts
    401
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    any recommendation for a good water heater controller that works with a wifi ? heater is 208 volts 30 amps
    Miguel
    All things, therefore, that you want men to do to you, you also must likewise do to them
  2. #2
    Join Date
    Jun 2003
    Hawthorne, New York NEC: 2014
    Posts
    4,135
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    I would think that such would be a feature of the water heater from the manufacturer. Not something aftermarket.
    -Hal
  3. #3
    Join Date
    May 2005
    Tacoma, WA
    Posts
    234
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by mtnelectrical View Post
    I use Wemo with a 30A contactor. Works great.
    http://www.belkin.com/us/p/P-F7C030;...7B1B7E61F092F/
  4. #4
    Join Date
    Feb 2007
    USA
    Posts
    5,808
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    There are wifi water heaters as well as devices rated at 30 amps that can control the circuit.
    If it is really desired I'd get the water heater with the Wifi because you can control the temp remotely.
  5. #5
    Join Date
    Mar 2006
    Essex, New Jersey
    Posts
    401
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Sierrasparky View Post
    I forgot to mention that the water heater just has been replaced.
    Miguel
  6. #6
    Join Date
    Jun 2003
    NE (9.1 miles @5.07 Degrees from Winged Horses)
    Posts
    10,436
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Why would someone want to control a water heater via WiFi? Other than, they can.
    Tom
    TBLO
  7. #7
    Join Date
    Dec 2006
    Eastern Oregon
    Posts
    3,674
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by ptonsparky View Post
    Turning the temp down when going on a long vacation?
    Mine has a control board on the top with 4 settings you can do right on the water heater. I guess WIFI would allow them to do it later if they forgot to do before they left the house. But how often would you really need to do that?
    Sounds like more things to go wrong to me....
  8. #8
    Join Date
    Dec 2007
    NE Nebraska
    Posts
    39,167
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Cow View Post
    exactly.
    These only have value to gadget junkies. Maybe someone that is obsessed with saving every tiny bit of energy they can or way to involved in being green for the planet (but those people shouldn't by nature even be interested in a tank type water heater) would also have an interest in such a product. Tank type water heater doesn't cost that much to maintain the tank when you aren't ever using any hot water. On top of that losses are only total losses during cooling season or if the tank isn't in a conditioned space (not happening here or you will have frozen pipes in the winter). During heating season those losses just supplement the heating system.
    I recently seen a garage door opener with wifi abilities. What is so important about needing wifi to communicate with your garage door? Sure you might be able to remotely open the door from half way around the globe, but how bad is the need to do so? That same GDO I was asked to connect a new "wired wall control" for it, as the old one stopped working. New one didn't work either - problem in the main unit - the old wall control did work on the second door opener they had. What was wrong with the traditional simple normally open contact that we used to put inside the garage as a control? I can understand something with additional security for an outdoor control. I ended up fixing that one with a wall mount wireless controller. Sends same kind of signal as the vehicle remotes, just designed to mount on the wall. Was a lot cheaper then a new circuit board for the door opener.
    I live for today, I'm just a day behind.
  9. #9
    Join Date
    Sep 2008
    UK
    Posts
    12,703
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    How about just turning it off? Or is that too simple?
  10. #10
    Join Date
    Dec 2007
    NE Nebraska
    Posts
    39,167
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Besoeker View Post
    Yes, too simple.
    When you come back and turn it on again - that is for some reason the time some component will fail.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
