User Tag List
Results 1 to 2 of 2
Thread: Grounding
  1. #1
    Join Date
    May 2018
    Arizona
    Posts
    1
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Grounding
    Hey everyone this is my first post and hoping someone can help me. I'm first year apprentice and just got my first solo job and need some advice. I have a portable welding table that im working on and i have to go through and make it up to code. This portable table has a 30kva 480/208 delta/wye transformer. I have 6/4 so cable with a plug feeding the transformer and i have #2xhhw on my load side going to a 90a main circuit breaker in a sub panel on the same table. I was reading the tables and i feel like i should use a number 8 for my ground wire to my ground bar inside the panel and connect it to my grounding lug thats connected by a jumper to the neutral on the load side. Is this okay?? Thank you.
  2. #2
    Join Date
    Dec 2006
    Chapel Hill, NC
    Posts
    34,587
    Mentioned
    4 Post(s)
    Tagged
    0 Thread(s)
    I am closing this thread because as an apprentice this is not a job you should be doing and I fear there is danger involved
    They say I shot a man named Gray and took his wife to Italy
    She inherited a million bucks and when she died it came to me
    I can't help it if I'm lucky
Posting Permissions
  • You may not post replies
  • You may not edit your posts
