User Tag List
Results 1 to 3 of 3
Thread: Fiber optic Help
  1. #1
    Join Date
    Aug 2016
    New Jersey
    Posts
    6
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Fiber optic Help
    hello,
    I need some help with fiber optic accessories
    I am working on new Fiber optic job connecting 3 locations with 24 strand multimode 50/125 (already purchased)
    so I am thinking to order three patch panels WCH-04P (Corning) ( one at each location)
    Also to order 2 Closet Connector Housing (CCH) PART NO. cch-cp12-g7) at each end location to land the cable.
    The "in" between location to have 4 Closet Connector Housing (CCH) PART NO. cch-cp12-g7 and I will locally jump the 22 fiber
    and I will use 10 feet SC to SC jumper to connect my equipment
    I really need help to make sure these accessories will work
    Thank you
  2. #2
    Join Date
    Feb 2003
    Bremerton, Washington
    Posts
    8,029
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Not familiar with those corning numbers. we purchase our corning from Graybar, they have a large data comm division that should be able to assist you
    Moderator-Washington State
    Ancora Imparo
  3. #3
    Join Date
    Apr 2013
    Pennsyltucky
    Posts
    7
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by stevdan View Post
    hello,
    Thank you
    You'll need three of the wall mount cabinets WCH-04P and eight of the panels cch-cp12-g7 at a minimum.
    I would probably split the middle closet into two cabinets so it's not full the day it's installed - a little more room to work, and leaves room for expansion - but it's not a big deal.
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
