User Tag List
Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 11 to 20 of 27
Thread: Ground rod in disturbed back-fill
  1. #11
    Join Date
    Mar 2008
    Michigan. It's a beautiful penninsula, I've looked around.
    Posts
    10,523
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by kwired View Post
    I can recall many places where soil is sandy and you can nearly push a rod all the way in with bare hands.
    I live in such an area. The dirt near Lake Michigan is white sand. I can usually push a ground rod down 6-8 feet by hand in some areas.
    Cheers and Stay Safe,
    Marky the Sparky
  2. #12
    Join Date
    Dec 2007
    NE Nebraska
    Posts
    41,030
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by K8MHZ View Post
    I live practically right on the border of where the "Nebraska sandhills region" begins. Have both heavy soils and sandy soils all around me. In fact where my house sits is all sand, go just a few hundred feet to the rear and there is clay soil back there. Kind of a mix at the surface but dig down and it is all clay.
    Many of sandy areas you only push the rod in 5 or 6 feet and it gets too hard to push any further by hand. Go to a high water table area and you may push it all the way in pretty easily though.
    I live for today, I'm just a day behind.
  3. #13
    Join Date
    Mar 2008
    Posts
    10,523
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Years ago we did a job where we had to put the rods in new sandy back fill. We would push them down to about a foot tall until we needed a hammer, but if you used too big of a hammer, the rod would disappear and you would have to dig down and pull some of it back up.
    Marky the Sparky
  4. #14
    Join Date
    Jul 2013
    Resting under the Major Oak UK
    Posts
    1,330
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Wire-Smith View Post
    do you think crushed limestone would be good back-fill, or slightly corrosive?
    Get limestone washings (quarry sand). It’s fine, it holds water well and mixed with 25% Bentonite clay will be as good as you’ll get.
    The reports of my death are greatly exaggerated.
  5. #15
    Join Date
    May 2018
    Ohio
    Posts
    379
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    thanks for the great responses everyone, does anyone have any published data or a suggestion on where to maybe find something published that says this is a good idea? thank you very much for the suggestions already
  6. #16
    Join Date
    Aug 2004
    Northern illinois
    Posts
    17,422
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    the problem with your question is it assumes somehow that a "better" ground is somehow desirable. Most cases it just does not matter.
    Bob
  7. #17
    Join Date
    May 2018
    Ohio
    Posts
    379
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    i will look into the chemical ground rods using bentonite should get me some published information for reasoning, thanks dennis
  8. #18
    Join Date
    May 2018
    Ohio
    Posts
    379
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
  9. #19
    Join Date
    Dec 2007
    NE Nebraska
    Posts
    41,030
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    If you put same soil back in the hole but don't compact it to same consistency it was before removing it- you likely have more resistance to ground then you would have had if it were driven. Over time it may eventaully work itself to about where it would have been if driven though.
  10. #20
    Join Date
    Apr 2008
    Austin, TX
    Posts
    1,211
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    After reading post #2, I looked at my 2008 NEC. Rings are "buried", rods are "driven", and plates are "installed". Only the NEC could come up with three ways to say "covered in dirt."
Posting Permissions
  • You may not post replies
  • You may not edit your posts
