User Tag List
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 18
Thread: Step Up Transformer
  1. #1
    Join Date
    Feb 2010
    Posts
    858
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Step Up Transformer
    Does Square D / Schneider make a Step Up SINGLE PHASE Transformer with a primary voltage of 120/240v and a Secondary Voltage of 277/480v-1?
    I've been looking through the digest and using the product selector and havent been able to find one.
  2. #2
    Join Date
    Jul 2003
    New Jersey
    Posts
    27,241
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Do you need both 277 and 480 on the secondary?
    Rob
  3. #3
    Join Date
    Feb 2010
    Posts
    858
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    No. This is a large warehouse with a 240/1 service but due to the size of the warehouse, I want to use 277v for the high bay lighting.
  4. #4
    Join Date
    Feb 2009
    Durango, CO, 10 h 20 min without traffic from winged horses.
    Posts
    10,035
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    You can't get 277V without three phase.
    If you don't think too good, don't think too much.
  5. #5
    Join Date
    May 2005
    Richmond, Virginia
    Posts
    25,198
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Npstewart View Post
    First, you can step 240v up to 277v with a buck-boost. But, why can't you just use the 240v?
    Second, the difference in current between the two probably isn't worth adding the transformer.
    Quote Originally Posted by ActionDave View Post
    Sure you can. I found a 120v-to-277v lighting transformer.
    Code references based on 2005 NEC
    Larry B. Fine
    Master Electrician
    Electrical Contractor
    Richmond, VA
  6. #6
    Join Date
    Jul 2006
    Posts
    8,657
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Pointless exercise, waste of money for the transformer, Just use 240V for the lighting if it’s all new.
    Unless you ALREADY have 277V ballasts / power supplies in your light fixtures, in which case, as mentioned, just get a boost transformer to go 240-277V, it will be less expensive.
    __________________________________________________ ____________________________
    Many people are shocked when they discover I am not a good electrician...
  7. #7
    Join Date
    Feb 2009
    Posts
    10,035
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by LarryFine View Post
    Well I'll be. Learned something new.
  8. #8
    Join Date
    May 2005
    Richmond, Virginia
    Posts
    25,198
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    That can happen here if you're not careful.
    Larry B. Fine
    Master Electrician
    Richmond, VA
  9. #9
    Join Date
    Apr 2009
    Williamsburg, VA
    Posts
    6,042
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I think you were meaning you cannot get 277/480 volts on the secondary without a 3-phase input, in which case you are correct.
    Without knowing what type of lights the original poster has, their current draw/kW rating, how many are on a circuit, etcetera, there is no way to advise whether or not he could wire them with 240 volts. The additional amperage at the lower voltage could very well exceed what the branch circuit wiring or circuit breakers can handle.
    What size transformer did you need?
  10. #10
    Join Date
    Jul 2003
    New Jersey
    Posts
    27,241
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    That's why I asked, since you only need to go from 240-277 and not 480 you should be able to find a suitable 1Ø transformer. If you were searching for 1Ø, 240-277/480 transformer I don't think that you will find one without going to 3Ø.
    Rob
Posting Permissions
  • You may not post replies
  • You may not edit your posts
