User Tag List
Page 2 of 2 FirstFirst 1 2
Results 11 to 19 of 19
Thread: What is this feeder tap
  1. #11
    Join Date
    Jul 2017
    MD, USA
    Posts
    628
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by kwired View Post
    The bus itself is a feeder, presuming it has current carrying capacity no less then the overcurrent device protecting it.
    Any conductors that attach to it are just extensions of the feeder if they have an ampacity equal or greater then the overcurrent protection ahead of them. If they have ampacity less then the overcurrent protection ahead of them then they are feeder taps.
    Switchboard feeder breaker load side feeder cables to trough bus are 2 sets of 4-600 kcmil 2/0G protected by 2500 amps bolted pressure switch upstream.
    The conductors to one of the tenants disconnect from the trough bus is 4-600 kcmil, 3/0G.
    The conductors to second tenant disconnect from the trough bus is 4-600 kcmil, 3/0G.
    Sent from my SM-G935U using Tapatalk
  2. #12
    Join Date
    Jan 2007
    Posts
    3,853
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by codequestion View Post
    That should have been the description from the beginning.
    If the 2500 amp FEEDER terminates on a buss, then the (2) Disconnects that are tapped off of it are Feeder Taps.
    JAP>
  3. #13
    Join Date
    Jan 2007
    Posts
    3,853
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Although the cable size for the 2500 amp feeder seem to be lacking some what.
    JAP>
  4. #14
    Join Date
    Jul 2017
    MD, USA
    Posts
    628
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Slight edit to feeder cable size for those who pay attention since protected by 2500 amps bolted switch:
    Switchboard feeder breaker load side feeder cables to trough bus are 7 sets of 4-500 kcmil 350kcmil G protected by 2500 amps bolted pressure switch upstream.
  5. #15
    Join Date
    Jul 2017
    MD, USA
    Posts
    628
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by jap View Post
    JAP>
    You caught that while i was editing it. Thats really good.
  6. #16
    Join Date
    Jan 2007
    Posts
    3,853
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Hey,, we're professionals around here...
    JAP>
  7. #17
    Join Date
    Jul 2003
    New Jersey
    Posts
    26,633
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    How about doing us all a favor by including all of the pertinent information in the OP.
    Rob
  8. #18
    Join Date
    Jul 2017
    MD, USA
    Posts
    628
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by infinity View Post
    Can i get more than 15 minutes?
  9. #19
    Join Date
    Feb 2003
    Fl
    Posts
    17,481
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    No, you've been told about doing this before. When you start a thread include the pertinent information from the start.
    Start a new thread with all the info.
    Roger
Posting Permissions
  • You may not post replies
  • You may not edit your posts
