User Tag List
Page 3 of 7 FirstFirst 1 2 3 4 5 ... LastLast
Results 21 to 30 of 62
Thread: Batteries For Home Standby Power
  1. #21
    Join Date
    Dec 2012
    Placerville, CA, USA
    Posts
    20,153
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by kwired View Post
    They would all want to come over to the one place that has light, heat, etc.
    If lead acid batteries and they vent anything it will be hydrogen gas - possibly something to be more concerned about then having a few gallons of gasoline stored somewhere on the premises.
    Maybe the condo needs to look into some sort of generator to supply the entire place. Don't know how to make the cost fair to everyone, as not everyone necessarily uses even amounts of energy when it is needed.
    If they are flooded lead acid (FLA) batteries, I would be much more concerned about the acid mist that is vented regularly when the batteries are gassing during charging than the hydrogen/oxygen gas mixture.
  2. #22
    Join Date
    Jun 2005
    Massachusetts
    Posts
    1,598
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by GoldDigger View Post
    Is it a given that lithium ion batteries would be the right choice?
  3. #23
    Join Date
    May 2011
    Posts
    5,076
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by gadfly56 View Post
    The OP's customer lives in a condo. "No solar panels for you."
    While it can be an obstacle, there is nothing about living in a condo per se that prohibits solar panels. There's actually a law now in California that prevents condo HOAs from having blanket prohibitions. Don't know about Massachusettes though...
  4. #24
    Join Date
    Oct 2007
    New Jersey
    Posts
    6,539
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by mkgrady View Post
    FLA or SLA batteries don't like it when you draw them down very far. Even marine rated FLA's for deep cycle shouldn't go below about 50% or so. LiO batteries, like the Tesla Powerwall 2 can go pretty much to empty without issue (nominal 14 kW-hr, available 13.5 kW-hr).
  5. #25
    Join Date
    Oct 2009
    Austin, TX, USA
    Posts
    10,797
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by jaggedben View Post
    Not specifically, but in many multi story condominium buildings, no single tenant owns any part of the roof.
  6. #26
    Join Date
    May 2014
    AZ
    Posts
    2,470
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    dont batt the whole place.
    fridge, some lights, washer, TV cable box & tv (for news & Netflix while power is out), etc.
    is the whole place electric? or is the dryer, stove, and water heater gas?
  7. #27
    Join Date
    Jun 2018
    Arcata, CA, USA
    Posts
    49
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    When we have residential customers who want a solar system designed to carry their entire load the first thing we insist on is a comprehensive energy audit of their home and then sit down with them to figure out ways to both reduce their demand and even more importantly, their expectations of what their new system can or will feasibly do when they find themselves temporarily off grid. If it's just a couple days they can get by with a few kWh worth of portable battery power. If it's the zombie apocalypse they're probably gonna bail on that condo anyway.
    I have a customer that asked for a quote for a standby generator for his townhouse condo. I gave him the quote for a 16kw unit. It was going to power his entire load with load shedding relays on the electric oven, dryer and AC. Now he says he does not think the condo board will approve a standby because of the noise during exercising or running during an outage. He is suggesting a battery and an inverter.
    My response without any real experience with batteries powering a home is that it would be expensive. He wants me to look into it and I am willing. If nothing comes of it I should still learn something. He has plenty of room in his unfinished basement for batteries.
    He is willing to forget about powering all that a 16kw standby could handle. He listed all the critical things that we can all imagine....gas burner for heat system, refrigerator, tv, WiFi, microwave, a few
    Lights, etc.. I explained that some of these loads are connected to circuits that supply other than the critical stuff and the system would have to be large enough to power whatever is connected or plugged in.
    I’m looking for some feedback on how practical this concept is. I would assume the system would need about 5kw peak load and have an average output of 2kw. These numbers are just shooting from the hip. If these numbers are anywhere near close, how big of a battery would I need to survive a power outage for four days?
    My gut tells me the battery bank would be enormous, the inverter battery charger would cost a fortune and I’m not sure what the transfer equipment would be. Anybody have opinions on this?
  8. #28
    Join Date
    Jun 2005
    Massachusetts
    Posts
    1,598
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by FionaZuppa View Post
    Yes that is the plan (post #1) to just run the essential circuits but I figure that will often be about 2KW and short burst of up to 5KW for when the fridge kicks on while the microwave is running and someone starts a toaster.
    Heat is gas, Electric dryer, Oven and AC but I would not power any of those things from the battery
  9. #29
    Join Date
    Apr 2009
    Williamsburg, VA
    Posts
    6,042
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    You can get away with a much smaller than 5 KW inverter or inverters if the customer understands the limitations of it... That is not running the microwave and toaster at the same time.
    Customer would be better off buying a small dorm fridge for essentials, and buying a lower wattage microwave...those two items will probably cost about 250 bucks, which is about the cost of one good AGM deep cycle battery. Also, they should get a two slice toaster oven instead of a four or six that they probably have.... or only toast two pieces of bread at once
    They must absolutely do everything they can to pare down their power usage, otherwise it will cost a small fortune in batteries to run those loads for 4 days. If they have a porch or terrace, you could put solar panels on a rolling cart of sorts. I would also be inclined to make the battery/solar setup a standalone system not tied into the condos electrical system, and just use extension cords to power the desired loads.
  10. #30
    Join Date
    Jan 2016
    Earth
    Posts
    6,049
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
Posting Permissions
  • You may not post replies
  • You may not edit your posts
