User Tag List
Results 1 to 5 of 5
Thread: Romex in NYC residential
  1. #1
    Join Date
    Jun 2018
    Ny
    Posts
    2
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    What's up fellas
    My brother just bought a house in NYC, ozone park to be exact. He wants me to add some recessed lighting.
    I work out on Long Island where nm romex is the standard, and it's been a long understanding that this is a no go in NYC.
    Recently talking to a buddy he said it has since been changed and romex is ok to use in a residential application not exceeding 3 stores in a multi family dwelling? He also mentioned that when running 15amp lighting circuits I must use 12 wire not 14.
    Any clarity on this topic would be greatly appreciated, thanks!
  2. #2
    Join Date
    Jul 2003
    New Jersey
    Posts
    27,227
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    The minimum conductor size in NYC is #12 so don't bother with any 15 amp circuits. Look here for the NM cable requirements:
    https://www1.nyc.gov/assets/building...rical_code.pdf
    Rob
  3. #3
    Join Date
    Feb 2003
    New York, 40.7514,-73.9925
    Posts
    4,775
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by infinity View Post
    Specifically 334.10 Uses Permitted
    and 334.12 Uses Not Permitted
    Those are amendments to the 2008 NEC
    Ron
  4. #4
    Join Date
    Jun 2018
    Ny
    Posts
    2
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Talk about quick replies, thankyou both so much.
    According to those articles it looks like I'm good to use 12/2 romex up in the finished ceiling for the lights.
    And I need to run a dryer line in the basement, ceiling is not finished, according to this in guessing drilling thru the studs in the ceiling then changing over to a piece of emt to get down the wall is ok?
    Thanks again for the help guys!
  5. #5
    Join Date
    Oct 2012
    nyc
    Posts
    312
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I would use wiring method that already exists in the house to make the installation consistent. If there was type AC (bx) cable used I would stick to it.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
