User Tag List
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 12
Thread: Resistor brazing
  1. #1
    Join Date
    Jun 2018
    Jharkhand, India
    Posts
    21
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Resistor brazing
    I think resistor material is made up of tungsten used in vfds, may be I am be wrong.
    so how to weld or braze if it is broken somewhere in the middle part.
    I mean what welding rod, gas for heating, etc for a proper joint bcoz it is mounted on a shaky platform or if i say on a crane itself.
    Insearch of clear concepts
  2. #2
    Join Date
    Oct 2007
    New Jersey
    Posts
    6,589
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Abhi View Post
    I'm not sure that "repairing" a resistor is the sort of thing that should be attempted in the field. How big is this resistor, what is it for, and why not just replace it?
  3. #3
    Join Date
    Jun 2018
    Jharkhand, India
    Posts
    21
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by gadfly56 View Post
    its 8 ohms, 5 KW rating resistor
    20 strips of resistor is combined in series to form 8 ohms
  4. #4
    Join Date
    Apr 2008
    Ann Arbor, Michigan
    Posts
    7,725
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    180614-1024 EDT
    Tungsten would not normally be used as a resistor resistance material.
    See http://www.resistorguide.com/materials/ nichrome.
    Power resistors do not run red hot like cooking elements, but the wire does get quite hot.
    https://www.engineeringtoolbox.com/t...ity-d_429.html
    I could not find one table with nichrome, brass, steel, and copper with their thermal conductivities. You have to go to different tables and different units. But brass is a better conductor of both heat and electric current than nichrome. I don't think brass used to solder nichrome wou;d be at too high a temperature when the nichrome is used as resistor material.
    The following two links do not work from this post.
    https://en.wikipedia.org/wiki/Nichrome
    https://en.wikipedia.org/wiki/List_o...conductivities
  5. #5
    Join Date
    Oct 2007
    New Jersey
    Posts
    6,589
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by gar View Post
    180614-1024 EDT
    The links worked perfectly fine for me from inside your post.
  6. #6
    Join Date
    Aug 2004
    Northern illinois
    Posts
    17,422
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I am not sure you can weld it back together. Might be easier to just splice it.
    Bob
  7. #7
    Join Date
    Dec 2012
    Placerville, CA, USA
    Posts
    20,230
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by petersonra View Post
    A suitable crimp connector might be the best way to go. Or a split-bolt?
  8. #8
    Join Date
    Aug 2017
    Los Angeles CA
    Posts
    216
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Replace the damaged part!
    This is not something you want to kludge in a high power VFD.
  9. #9
    Join Date
    Jul 2006
    Posts
    8,651
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    It will be NiCh (Nickel - Chromium alloy) resistance wire, and it is not repairable. If you try to repair it, you add resistance to that element and when used in a grid like that, that element in the gris simply conducts less, so the other elements carry more of the workload and fail sooner. Just replace that element.
    __________________________________________________ ____________________________
    Many people are shocked when they discover I am not a good electrician...
  10. #10
    Join Date
    Aug 2004
    Northern illinois
    Posts
    17,422
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Jraef View Post
    he said they were in series so if he spliced it back together the whole resistor might have a slightly higher resistance. probably not enough to make any real difference.
    the ends of the resistors made this way just have terminals that are clamped on to the wire. They work fine. No reason a proper splice would not work.
    Bob
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
