Results 1 to 2 of 2
Thread: low voltage [ 24 volts AC ] multi conductor irrigation sprinkler wire in attic.
  1. #1
    Join Date
    Jun 2018
    Southern California
    Posts
    1
    Can you run 24 volt AC Low Voltage direct burial sprinkler wire in an attic? Irrigation controller is in the laundry room and shortest route is thru the attic. Would it have to be put into conduit.? Would NM ,PVC be appropriate ?
    Thanks
  2. #2
    Join Date
    Dec 2006
    Chapel Hill, NC
    Posts
    33,565
    I am closing this thread, in accordance with the Forum rules. This Forum is intended to assist professional electricians, inspectors, engineers, and other members of the electrical industry in the performance of their job-related tasks. However, if you are not an electrician or an electrical contractor, then we are not permitted to help you perform your own electrical installation work.
    If I have misjudged the situation, if for example this project is related to your work, then send me a Private Message. If you can show me that I am wrong, and that you are a licensed electrician (or at least a licensed apprentice), then I will reopen your post, and offer an apology for the delay and inconvenience.
    A reminder to all members, if you see a questionable post, feel free to report it by clicking the button at the bottom left corner of the post.
    They say I shot a man named Gray and took his wife to Italy
    She inherited a million bucks and when she died it came to me
    I can't help it if I'm lucky
Posting Permissions
  • You may not post replies
  • You may not edit your posts
