User Tag List
Results 1 to 5 of 5
Thread: POE Switch, DIN Rail, industrial rated
  1. #1
    Join Date
    Feb 2003
    Bremerton, Washington
    Posts
    8,041
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I am looking for a recommendation on a 4 port (more or less) POE switch, DIN rail, 24 VDC, to use in an industrial control panel with VOIP phones
    Moderator-Washington State
    Ancora Imparo
  2. #2
    Join Date
    Aug 2004
    Northern illinois
    Posts
    17,284
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
  3. #3
    Join Date
    Dec 2012
    Placerville, CA, USA
    Posts
    20,030
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    When you say POE switch it is a bit ambiguous whether you mean one that gets its power from one of its inputs or one that sources POE to some or all of its ports. Or even just passes POE through.
  4. #4
    Join Date
    Aug 2013
    New York, NY
    Posts
    534
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    5-port gigabit unmanaged switch, with (4) PoE ports:
    https://www.automationdirect.com/adc...E/SE2-SWP5UG-T
    You'll need a 48VDC power supply for it:
    https://www.automationdirect.com/adc...unt/PSB48-120S
    SceneryDriver
  5. #5
    Join Date
    Sep 2008
    Taylorsville, UT
    Posts
    169
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by GoldDigger View Post
    Typically, in networking, a PoE switch is a switch that provides power to the connected devices. More often than not, the switch provides power to the port only if the device requests it (so you don't need to worry about plugging a PC into a PoE switch). Some switches have DIP switches to turn power on/off for each port.
    CIAO!
    Ed N.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
