Results 1 to 2 of 2
Thread: Tapping Bus
  1. #1
    Join Date
    Sep 2012
    NJ
    Posts
    2,215
    Tapping Bus
    Sorry guys. If replacing fuses wasn’t able to be done(I don’t know why) and I had to tap the bus( can you tap bus without drilling into it?) would the switch have to be removed? Guess it should be anyway since it would no longer be needed as we would mount one externally. Thanks.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	20609   Click image for larger version.
  2. #2
    Join Date
    Aug 2004
    Northern illinois
    Posts
    16,930
    I think in a very legalistic way you would not be allowed to drill the bus.
    You might be able to get a tap kit from the manufacturer.
    You could just connect to the load side of the switch too.
    Bob
Posting Permissions
  • You may not post replies
  • You may not edit your posts
