User Tag List
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 14
Thread: CAL FIRE Guideline outside California
  1. #1
    Join Date
    May 2013
    Massachusetts
    Posts
    2,450
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Do any other states have statewide standards for how to lay out setbacks and access paths on rooftop solar arrays? If so, where could one find them? Is there any imminent possibility of the California rules becoming a national standard?
  2. #2
    Join Date
    Feb 2003
    Illinois
    Posts
    23,961
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Carultch View Post
    You would have to check with the AHJ for the area that you are looking at. A number of areas have rules like that for firefighter access. In my opinion, all areas should have such rules.
    Don, Illinois
    (All code citations are 2017 unless otherwise noted)
  3. #3
    Join Date
    Oct 2009
    Austin, TX, USA
    Posts
    10,639
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    In Texas it isn't statewide but local AHJ's choose whether or not to enforce fire code, and then commercial PV is looked at differently from residential PV. Virtually all if not all Texas AHj's enforce fire code (actually I think it's part of building code) on commercial systems but only about 20% do for resi systems.
  4. #4
    Join Date
    May 2011
    Posts
    4,960
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Funny you should ask now, since the CA code is going to change majorly in two days.
  5. #5
    Join Date
    Feb 2003
    San Jose, CA
    Posts
    1,542
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by jaggedben View Post
    I don't install normally PV systems but just posted a thread about installing a system for myself. Can you share what the major changes are or provide a link.
    I'm currently planning minimum 3' from the ridge and 3' paths on both sides of the array. I will only have panels on 1 side of a valley so don't need to comply with the 18" clearance.
    Thanks
    Curt Swartz
    Electrical Contractor
  6. #6
    Join Date
    Apr 2007
    Berkeley, CA
    Posts
    1,799
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I think it is the new section R324.6 in the CRC (Title 24, part 2.5), available here: http://www.bsc.ca.gov/Codes.aspx
    Cheers, Wayne
  7. #7
    Join Date
    Feb 2007
    USA
    Posts
    5,814
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Not so fast. Just meetings and public comment thru Aug.
    code effective date Jan 2020.
  8. #8
    Join Date
    May 2011
    Posts
    4,960
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by curt swartz View Post
    Biggest change is only 18" required from the ridge, if your not using more than a third of the roof. Generally more flexibility is allowed on the placement of pathways, except that now one must be streetside. You still need at least two overall.
    Quote Originally Posted by Sierrasparky View Post
    Nope. There are a supplements that go into effect on Sunday.
  9. #9
    Join Date
    May 2011
    Posts
    4,960
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
  10. #10
    Join Date
    Feb 2007
    USA
    Posts
    5,814
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    So it is. I missed that.
    I don't get what was changed to 210.**
Posting Permissions
  • You may not post replies
  • You may not edit your posts
